Shudder issues
Old May 17, 2019 | 04:47 PM
elejes's Avatar
elejes
Default Shudder issues
My Ls 460 started shuddering suddenly. I thought it was the plugs but it’s not.
my mechanic recommended me to get a transmission flush to see if it helps.
He thinks it’s the converter, but to give it a try. Anyone ever had this issue? What’s the damage to get a transmission flush at the dealership?
thanks!
Old May 17, 2019 | 04:49 PM
elejes's Avatar
elejes
By the way, the symptoms are that the car shudders between 20-45 mph. Not a problem at high speeds.
I replaced the radiator about a year ago and a bit of transmission fluid leaked out while installing it. Could this be the culprit?
Old May 17, 2019 | 05:51 PM
elejes's Avatar
elejes
Originally Posted by FunFact
Did you read my vibration thread?
Yes I did. I will be replacing it, but something tells me that with my luck it won’t be the solution.
If it is, then never mind.
Old May 18, 2019 | 11:58 AM
jdanielca's Avatar
jdanielca
dont know how many miles your car has, but unless your mechanic is promising you a new tranny if the flush F's it up I would not do a flush... everyone here and everywhere say that flushes should be avoided. drain and fill or fluid exchange.
Old May 19, 2019 | 05:32 AM
fwhomeboy's Avatar
fwhomeboy
A drain and fill fixed that issue for me. NOT a Flush.
Old May 27, 2019 | 01:26 PM
elejes's Avatar
elejes
Issue ended up being the torque converter in the tranny. That was my biggest nightmare, and I was hoping that was not the issue.
I’m very disappointed in the vehicle.
will need to look at other options if any besides the $9000 quoted price to fix at the dealership.
very disappointed.
Old May 27, 2019 | 02:32 PM
jkittlesen's Avatar
jkittlesen
I wish you knew the condition(smell and color) of the ATF, by chance did your tech give you a clue as to that?
Could give you a clue as to condition!
Sorry for your troubles, it sucks to have the issues you have had .
Old May 27, 2019 | 02:39 PM
elejes's Avatar
elejes
They just said the tech was certain it was the torque converter. They recommended a tranny system replacement and that they couldn’t do a converter replacement because Lexus did not allow that. Recommended to look at a tranny shop elsewhere for for that to get more life out of the tranny.
I was hoping it was another thing. My best option is to find a good used tranny and somehow do a swap.
Old May 27, 2019 | 02:43 PM
jkittlesen's Avatar
jkittlesen
Just a thought ......maybe second opinion just to be sure?
It is a huge expense I know!
Old May 27, 2019 | 03:09 PM
fwhomeboy's Avatar
fwhomeboy
very disappointed.
Did you do a drain and fill? If you didn't then do that, please. Just do it.
Old May 27, 2019 | 06:16 PM
heidihidin's Avatar
heidihidin
is it a Lexus dealership that is telling you that you need a converter?
tow the car to the dealership
Old May 27, 2019 | 07:31 PM
jkittlesen's Avatar
jkittlesen
Yikes................if it were me, I would do a transmission service (filter ) which I just did to mine by the way before I took that diag!
We have DIY shop in Austin..............they supply a lift and all the tools, best thing going for an ex mechanic like me!
Rolling on a creeper...... doing a tranny service..................not for me any more!
Before you drop 6k minimum on a tranny...........do yourself a favor .........try this.............http://www.diyatx.com/
Old May 27, 2019 | 07:51 PM
fwhomeboy's Avatar
fwhomeboy
I wish we had that deal here in NC. How much does it cost?
Old May 27, 2019 | 07:55 PM
jkittlesen's Avatar
jkittlesen
Hard to find , only 7 in the country from what the owner says!
$25.00 an hour, it was if I had my own garage again, oh...............free bottled water and next to a Men's Club!
The staff was great!
