Center Armrest Removal
Old 03-19-19, 06:47 PM
LS430FL
LS430FL's Avatar
Default Center Armrest Removal
Hi all,
I would like to have my center armrest recovered. I bought a new cover but I can't seem to figure out how to remove the assembly so I can install. Has anyone done this? I am willing to take photos and do a write up if someone can guide me as to how to remove it. Thank you
Old 03-19-19, 08:26 PM
jdanielca
jdanielca's Avatar
Originally Posted by LS430FL
Hi all,
remove the rear ac vent and any accompanying trim, will reveal bolts....
Old 03-21-19, 09:36 AM
KYLS
KYLS's Avatar
Hi all,
I'm also looking to remove my console box to have a side panel re-glued. It is an 2008, so perhaps different than yours but I suspect not much. The front side panels are held on with clips and must be removed, connection to 12v socket and audio plugs unplugged. Finally their are two bolts under the mat on the floor of the box, and then I suspect one or two more toward the back behind the vent which jdanielca is referencing.
Might someone have a diagram to be sure all bolts are accounted for?
Old 03-21-19, 06:14 PM
LS430FL
LS430FL's Avatar
Oh wow this is a pretty involved project....I did try removing the a/c vent but wasnt coming out so easy. I started to make small marks in the side trim so I stopped as I didn't want to damage or snap anything.
Old 03-22-19, 02:50 AM
Overlander
Overlander's Avatar
LS430FL (03-22-19)
Old 03-22-19, 12:08 PM
KYLS
KYLS's Avatar
Exactly what I needed. Thanks!
Devor
SC- 1st Gen (1992-2000)
21
06-07-19 11:16 AM
hahahaf
IS F (2008-2014)
04-18-14 04:38 AM
Ali SC4
03-01-10 07:47 PM
acc
07-06-07 09:21 AM
Sniper615
RX - 1st Gen (1999-2003)
05-28-06 08:11 PM
Quick Reply: Center Armrest Removal
