Oil filter access flap mod
Old 12-09-18, 06:08 PM
Benjam1n
Benjam1n's Avatar
Default Oil filter access flap mod
That oil filter access flap was a pain changing oil on your back. Anyone who changes their own oil on the ground knows what I'm talking about. Thought about removing it, but did something else instead. Took the self drilling screw that secures it, folded the flap all the way back and self drilled the screw into the plastic underbody cover using a screwdriver. That way it holds itself up and out the way. Made draining the filter area much easier and cleaner. Afterwards just unscrewed it, put the flap back in position, and screwed it in the usual spot. Worked well.
NotFasty (12-10-18)
Old 12-09-18, 06:38 PM
Chuckinnj
Chuckinnj's Avatar
Adhesive VELCRO strips works too!
NotFasty (12-11-18)
Old 12-09-18, 06:47 PM
roadfrog
roadfrog's Avatar
Yep....a few of us did this on our LS's.
Old 12-09-18, 08:51 PM
johnnyg66
johnnyg66's Avatar
Mine was gone when i took ownership. I have thought of replacing the whole panel but at $240 bucks had second thoughts.
NotFasty (12-11-18)
Old 12-10-18, 12:35 PM
Oliver Enterprises
Former Sponsor
Oliver Enterprises's Avatar
Beat me to it. We just didn't post up about it (our flaw).
Old 12-10-18, 04:59 PM
Benjam1n
Benjam1n's Avatar
Lol, just saying what worked for me here Ollie. Sorry I don't sell exhaust parts like you.
Old 12-11-18, 05:13 AM
Oliver Enterprises
Former Sponsor
Sorry, I didn't mean to come off offensive. My intention was that it's a valuable thing to post about. But I wasn't clever & proactive enough to initiate a thread about it. Props to you.
The following 2 users liked this post by Oliver Enterprises:
NotFasty (12-11-18), roadfrog (12-13-18)
Old 12-11-18, 01:25 PM
213374U
213374U's Avatar
I'm able to bend the door and simply tuck it under the lip of the front bumper to hold it out of the way, no "mod" necessary.
Old 12-12-18, 05:10 AM
Oliver Enterprises
Former Sponsor
Are you sure you're thinking about the same door, and/or the same vehicle? From my memory, the oil filter door is a long way from the front bumper, and not long enough to reach it. I *think* you're thinking of another door.
But yeah, after I started using the screw to hold the door back, I started thinking, man, what a pain this must be with this door in the way. Because it's stiff and would be trying to close the whole time. It's already messy enough without having to fight the door.
Jason Oliver
Old 12-12-18, 09:46 AM
213374U
213374U's Avatar
I'll double check but I'm pretty sure there's a spot to tuck it away. Have an oil change coming up soon so I'll snap a pic or two.
Old 12-12-18, 05:44 PM
KYLS
KYLS's Avatar
I can tuck the flap on my ‘08 LS600hl too, but not on the ‘07 LS460. I suspect the door is longer or perhaps more forward. Regardless, I find using the screw provides larger filter access opening. I also have to check for leaks and close it while still on the ramps on the 600, for once down the ground prevents it from hinging around to closed with air shocks at normal height. Just my observations from past changes.
Old 12-18-18, 11:30 AM
213374U
213374U's Avatar
Confirmed during my oil change over the weekend. This is on my 2010 so I'm unsure if it's different on other models.
Old 12-18-18, 11:52 AM
Oliver Enterprises
Former Sponsor
Must be an AWD thing. My 2010's is not nearly that long … to reach to the front. And I want to say … mine's a bit more centered under the car (left to right). But that my just be my perception.
Old 12-29-18, 12:55 PM
KYLS
KYLS's Avatar
213374u’s picture looks much the same as my 2008 LS600hL. While changing the oil on the 2007 LS460L yesterday, I took a picture for comparison. This is RWD (pre-AWD option), so perhaps that explains relocation of filter and dipstick placement as Oliver Enterprises remarked.
tolian21
ES - 5th Gen (2007-2012)
08-31-21 03:40 AM
lilbluu
06-01-10 03:44 AM
yasu
05-18-10 06:49 AM
lexian
RX - 1st Gen (1999-2003)
07-29-02 09:31 AM
mjdart
IS - 1st Gen (2001-2005)
07-25-01 09:35 PM
Quick Reply: Oil filter access flap mod
