Front jack points? LS460 FSM photo isn’t that clear
Hi all,
trying to change my front brakes but having issues with jacking up my car. Is it this round point? Seems like it’ll slip being that smooth.
I used that exact spot to jack up the 460 earlier today. I was wary of it too at first but there are not a lot of other options. The plate was secure. There is a cross member right behind, or rather above, the plate. You can opt to remove the plate, but you'll need to remove some additional plastic covers near the front too, plus the silver plate I have tilted down in the photo because they're all hinged together.
The floor jack shown in the photo, is it a HF low profile long reach floor jack? or just a HF low profile floor jack, thanks,
I borrowed it from my Uncle because my regular jack was too tall to get underneath. It is a Harbor Freight 3-ton low profile, but did not appear to be long reach because at first i didnt think it would reach in far enough. Luckily the whole jack fit beneath and the handle was long and two-piece.
I have a HF and Arcan Low profile jack also. Felt like I have to jam the jack under there and jack it up and still lacking on reach.
I may buy a scissor jack for the LS though $$$$
My dream is to someday buy a for my garage. $1500-2000 doesn't sound too bad at all. The issue is more of space and unloading the units which can weigh 1200 lbs.
I have the 16000 pound ramps and they are good for quick oil changes. I do notice they have a tendency to slide if you go up to fast and you can bend them if you don't center the wheels properly . I also have the 3 Ton harbor freight Jack for brakes and other things. It's kind of heavy to pull it out of the trunk though. I need to pick up another 1 1/2 ton Jack which is much easier to lift and keep it in the trunk.
Im considering this:
https://www.quickjack.com/car-lift-s...-car-lift.html
He said 1.5 ton jack to keep in trunk which isn’t that heavy.
