Need Elegant Solution for Left Kick Panel
Old Oct 1, 2018 | 06:47 AM
ldmf's Avatar
ldmf
Default Need Elegant Solution for Left Kick Panel
My carpet on the driver's side, left foot kick panel is wearing thin. I am guessing my wear of Merrells is causing a premature wear spot.
I was wondering if anyone has an elegant solution for a plastic cover/carpet/whatever to cover this corner spot.
Let me know your thoughts.
Thanks in advance,
LDMF
Old Oct 1, 2018 | 11:00 AM
sktn77a's Avatar
sktn77a
A picture may help.
Old Oct 1, 2018 | 11:19 AM
comotiger's Avatar
comotiger
Thanks in advance,
LDMF
I suppose you are referring to the dead pedal spot. Here are two threads. The first one discusses various ways that CLers have addressed the issue. The second one describes my dead pedal modification, which is pretty elegant, if I may say so myself
https://www.clublexus.com/forums/ls-...rotection.html
https://www.clublexus.com/forums/ls-...pedal-mod.html
Old Oct 1, 2018 | 02:55 PM
ldmf's Avatar
ldmf
Here is a pic. It is actually to the left of the dead pedal.
The dead pedal solution was elegant.
Old Oct 1, 2018 | 02:58 PM
ldmf's Avatar
ldmf
My god is my car filthy.
Old Oct 1, 2018 | 04:29 PM
jdanielca's Avatar
jdanielca
wow thats not good... let me see if my weathertech mats go up that far i shall try and take a pic might keep your foot away eough but it looks pretty bad.. get one of those quilter looking mats that covers all sides
Old Oct 2, 2018 | 05:06 AM
jdanielca's Avatar
jdanielca
Old Oct 3, 2018 | 05:59 PM
sktn77a's Avatar
sktn77a
Wow, that's pretty bad. Two suggestions:
1. Dye it black - will be worn but much less apparent.
2. Cut out that section of carpet and replace it (a good uphostery or carpet shop should be able to do this quite cheaply).
Good luck.
Old Oct 3, 2018 | 07:39 PM
LS430FL's Avatar
LS430FL
I was just going to suggest some Rit dye on so that it is not so obvious. Can get it at any craft store or grocery store usually. Make sure water is very hot when you spray it on. Follow bottle directions. If not the above carpet repair suggestion may work as well followed by a weather floor mat to protect the area from wear occurring again.
PondScum
Sep 20, 2013 04:13 PM
Lexpilot53
RX - 1st Gen (1999-2003)
May 17, 2012 09:19 AM
jmoney1698
Sep 5, 2008 05:44 PM
Tego1090
Aug 14, 2008 06:23 PM
i3urton
Oct 7, 2007 08:35 PM
