Infrequently driven...
Old Sep 22, 2018 | 10:10 AM
StClair's Avatar
StClair
Default Infrequently driven...
So, I trAvel for work weekly and my 2016 LS 460 (just over 19k miles) sits frequently. I’ve noticed a lot of tyre noise when I’m driving especially when coming to a full stop. The noise is a cycling thud-thud-thud until I stop. I assume it’s the tyres...is this reversible? 😔. Thoughts? Recommendations?
Old Sep 22, 2018 | 10:46 AM
TriC's Avatar
TriC
Could the tires be developing flat spots from sitting? If so, they should round into shape with some high speed cruising to get them good and warmed up. Surface rust on the brake rotors is another possibility. Again, use is the cure.
Old Sep 22, 2018 | 05:19 PM
StClair's Avatar
StClair
I concur...I need to drive it more often.
thanks!
Old Sep 24, 2018 | 12:34 PM
R Z's Avatar
R Z
How long at a time does the car sit?
Old Sep 24, 2018 | 02:15 PM
Nospinzone's Avatar
Nospinzone
It is the tires. Assuming the car only sits for a week or two, it should be reversible after you drive the car for a while. However, much depends on the manufacturer and type of tire. When it comes time for you to replace the tires, find one that has a hard compound. The easiest way to tell is to look for a tire that is rated for the longest mileage. Any ultra high performance tire will be softer and have a shorter life and be more susceptible to flat spotting.
One method to help reduce flat spotting is to inflate the tires to close to their maximum psi while the car is stored. Of course then you have to reduce the pressure before you drive it and then re-inflate when it goes back into storage.
Old Sep 24, 2018 | 04:30 PM
Dave144239's Avatar
Dave144239
You could always buy a set of these ramps to park the car on.
Amazon Amazon
Old Sep 24, 2018 | 08:17 PM
StClair's Avatar
StClair
Default Thanks!
My car is usually driven once per week...maybe 30 miles. Thank you all for the recommendations.
Old Sep 25, 2018 | 12:43 PM
Oliver Enterprises's Avatar
Oliver Enterprises
Former Sponsor
Some tires are more prone to flat spotting than others. 2010 model here, 43k miles, so it sits. It sits sometimes a couple to 3 weeks at a time. The Pirellis so far I haven't noticed flat spotting.
Alexia56
Mar 22, 2019 06:21 PM
ahde
Jun 2, 2017 04:58 AM
evopat
Aug 5, 2015 11:24 AM
EJ255t
Feb 10, 2015 06:03 PM
YOX
Jul 30, 2009 01:21 PM
