Synthetic OilAnyone use aftermarket engine oil filters like those from Mobil1? Please
jdanielca (08-22-18)
#32
so I am guessing our cars take less than 5L during an oil change ?
#34
The other option is toyota synthetic 0w20 that runs less than 10 USD a quart.
Price aside it is not a huge difference keeping in mind I only have the 5W20 option with quaker.. what should I get? Quaker or Toyota?
Also I cannot find Amsoil filters here in Ukraine or anywhere nearby. Neither can I find mobil1 filters. Bosch filters are easy enough to get I think, would that be better than Denso filters? or worse?
#35
I'd say get the cheaper of the two you have readily available.
47. 0W20 Toyota Motor Oil, API SN, synthetic = 101,460 psi
Ranks quite highly.
I wouldn't pay a huge premium for amsoil or Mobil 1 filters. Just get a good reasonable cost filter and change them regularly with your oil.
Ranks quite highly.
#36
Ranks quite highly.
Ranks quite highly.
#38
So I thought I'd share some interesting and different toyota oils we have here. So far I have found 3 in this one shop, there are Lexus branded ones some other place but I do not think they are any better than these. Use google chrome for auto translation and 1 USD = 26 UAH
First we have US spec:
https://prom.ua/p643803518-motornoe-...oyota;all.html
Then we have one labeled advance fuel economy that comes in 5L jugs
https://prom.ua/p643803533-motornoe-...oyota;all.html
And last but not least some japan spec ones produced by hydrocracking whatever that means that comes in 1 and 4L cans.
https://prom.ua/p643803525-motornoe-...oyota;all.html
Ok I am leaning towards the 5L jugs, but anyone want to chime in on the Japan spec ones?
#39
Help me understand something.... this graph shows that in cold temperature I should be using 5W20 right? So why does it say "However, SAE 0W- 20 is the best choice for fuel econ- omy and good starting in cold weather." Do they mean best compromise....
#40
Pretty certain the lower the cold temp viscosity number, the more well suited it is for colder climates. Using either 0w or 5w-20 oughta be perfectly fine. Don't overthink the viscosity, just change your oil and filter regularly instead.
#41
