Front suspension
Front suspension
Now sorry but i have to say it me bei g cheap i choose to replace my entire front suspension shocks struts control arms etc etc to resolve a noise issue but i bought all parts from buyautoparts.com ooops bad decision....
now 2 month later the problem is way bigger my cruise control if i hit a small podhole will cancel the speed acceleration., noise everywhere i need help to at least go back to square one please help me😏😏😏
I think you may have a bad brake switch which would affect the cruise control. Start with that. Part # is 84340-30110. About $35 shipped online. Very easy to replace. Look by the brake lever to see the switch. When the switch button is pushed in the Brake light are off.
You should be able to visually see if any of the new bushings are bad, this is highly unlikely. Check for loose bolts then check your front splash shield and bumper cover. Make sure they’re both tight by bumping them with your palm. A bumper cover with very little movement will make the same noise as a nasty suspension rattle. This was the case on my car. You can drill and fasten the bottom under part of the bumper cover to the bumper or any fixed point with sheet metal screws to tighten it up. I also removed the splash pan since that is just way too noisy. As for the cruise control the brake switch sounds feasible. I don’t see how the cruise would be related to the suspension.
Nothing wrong with the parts you bought from that site. Thanks for providing it. I may take a look there when I shop for parts. You may have a faulty sensor or switch that need to be replaced. You need a mechanic to do a system scan to find the problem.
Listen the rntire car rattle after i instqlled this part and if im driving fast and hita bump feel the struts cant support the car weight loud bang
Don't spend extra money you should not have to spend, you bought parts and had them installed and after just 2 months they are making noises and not functioning correctly. That is not your fault nor should you be responsible for correcting it, they are either defective parts or they were not installed correctly and either the place that sold you the parts or the person who installed them need to cover you. This could just be some bolts were not tightened correctly and just need to be tightened correctly.
Dealerships and some shops can put micro phones on the suspension to determine almost exactly where a issue is coming from, if you can't diagnose it take it to a dealership.
Take it to a dealer, pay the $150 for an inspection, and then you'll know EXACTLY what you need to fix. Nobody on this site is going to be able to do anything for you other than make educated guesses that will cost you money in parts and still may not fix your problem. Odds are you'll spend more if you simply take advice from here and start swapping stuff.
