Batteries batteries batteries
I've owned my car for a little over four years now. When I purchased it they put a brand new battery in, it was a little weak they said. No problems for two years, then it died. Replaced it with another new one. Now two years later it died again and I put another new battery in it.
So really in four years I've been through three batteries. This last battery I put in was part of a warranty from my previous battery (no charge). I figured I'd be continuing with my trend of burning through batteries and purchased one with a warranty (good idea).
I find with these cars there is no surviving a "weak" battery. They just can't provide the juice to start these things on initial start up. Between the telescoping steering wheel motor, turning over a V8, activating the electric steering, and assisted brake system, it's a bit too much. Never mind the amperage this car needs to "stay alive" when it's turned off. Probably doesn't help that I live in an area where the winters are hell (all three batteries were replaced in late December/early January).
Anyone else ripping through batteries in these things?
No? Still got the original battery and mine is 2014. I'm in MN and it was -15F last few night. We do have a heat wave coming in at about 36F TODAY!!!
Anyway, i guess i will change the battery out this coming summer...
-15F?? We had a two week article freeze over here, it never went above 10, but it never got lower than -7F (then again once you go -whatever, does it really matter?lol).
Not really, except fingers and eyeballs starts to "sting" Anyway, a pipe in my garage burst due to the cold, so the car has been parked outside... Some areas in MN had wind chill reportedly about - 30 to -40F
Why not try a nice AGM? I did mine when I got the car with the oem AGM because on the 8 it's a bit more complicated with sizing and coding the battery but they last a really long time in harsh conditions.
Doublebase (01-18-18)
I got about 9 years on my original battery. I replaced it with an Interstate and so far so good.
I was installing a sub in my LS yesterday and luckily, found out my battery needed to be replaced (Jan '13 manufactured date on the battery / Panasonic), so I did, with a Duralast Gold from Autozone.
The battery itself had to be turned backwards around but otherwise it fit without issue.
Given the OEM battery lasted nearly 5 years, let us hope this Duralast Gold will do the same.
Just bought an Innerstate Megatron plus battery at for $125. It has 800cca and 1000ca. Make sure your terminals are in good condition. My old positive copper one was very soft and corroded. I got the updated one from a Toyota dealer for about $25
I've had my 460 almost six years and I replaced my battery in Sept. This will be my third battery.
Megatron is a great battery. Bosch S6 is another. Personally, I would lean towards higher reserve vs CCA. They somewhat go hand in but higher reserve is more important. Not sure how big of a battery you can fit. You should see the size of the battery that is in my trunk. Damn thing weighs 70 lbs.
