08 LS 460 left me stranded
Old 11-16-17, 07:43 AM
minnyminh
minnyminh's Avatar
Starter is located on the right side lower portion of the engine. There's a lot of parts that needs to be removed to get it out. A lot of parts from top of engine and underneath ( exhaust manifold, alternator, stabilizer car,etc....)
Old 11-16-17, 11:56 AM
elejes
elejes's Avatar
Any chance you have a “how to” on it? Thanks!
Old 11-17-17, 06:12 PM
ghenley
ghenley's Avatar
I heard the noise for several days when starting the car before it no longer started. Once it started, I had full power. However, it was much worse when the car finally didn't start. Luckily, I had taken it to my mechanic to check it out - and it was there that it wouldn't start.
Old 11-18-17, 07:48 PM
elejes
elejes's Avatar
Tried cables no change. Does anyone know how to confirm in these cars if it’s the starter? Code came out as P0335, crankshaft position sensor A circuit.
Old 11-20-17, 04:22 PM
ghenley
ghenley's Avatar
Sorry, I don't know how to confirm. I took mine to my mechanic and he knew right away.
Old 11-20-17, 04:27 PM
Received 2,564 Likes on 1,848 Posts
Mechanic will know if its the starter.
Be happy its not an LS400 lol. My LS400 had an intermittent starter fault and a starter replacement on that car is like $1,200 from an independent mechanic, engine has to be raised, its a mess. We just endured the sporadic no starts for a couple years.
Old 11-20-17, 04:45 PM
elejes
elejes's Avatar
Thanks!
Ordered the Denso part from Amazon for $150 rebuilt ;(
I’ll be taking a gamble with my local mechanic who has done work for me in the past. Quoted me $320 which I think is a great deal.
Hoping it is the starter and not anything else. Also, I’ll be Ordering terminal covers too because I heard the heat fries them.
Wish me luck!
Old 11-20-17, 05:05 PM
$320? My guess is he's never done a starter on an LS before. Let us know how it goes!
Old 11-20-17, 06:08 PM
elejes
elejes's Avatar
Yeah, your right, but don’t jinx it.
I’ll let you know.
Old 11-20-17, 06:15 PM
You should get that estimate in writing lol
Old 11-21-17, 08:01 AM
roadfrog
roadfrog's Avatar
Indeed. Then we can all go see him if and when the time comes!
Old 11-21-17, 11:48 AM
elejes
elejes's Avatar
Your making me nervous, but if all goes well start saving your mula to get your vehicles to San Antonio, TX.
Old 11-21-17, 11:51 AM
elejes
elejes's Avatar
Always start with the battery, though in this case, I would suspect the starter. If it is the starter, your in for a treat (not really).....it's a biotch to get at. The starter is inexpensive, but labor (if you pay someone to do it), will be pricey with the standard being 6 hrs. For a start, the front part of the exhaust needs to be removed (inc the manifold), as well as the stabilizer bar and suspension reinforcement member. There's more, but that's the bulk of it.
So the access is from the top or bottom of the car? Or both?
Trying to give my mechanic a heads up.
Old 11-21-17, 11:54 AM
elejes
elejes's Avatar
As I mentioned in the previous posts, the car won’t start. Anyone with experience bypassing the starter relay? Can this be done to start my car and get it to my mechanic? Any help is appreciated.
Old 11-21-17, 12:38 PM
Falbz
Falbz's Avatar
Dont worry I had my starter done as well as rear diff fluid change for $300 👍 That estimate is doable
I provided all the parts / fluid
Quick Reply: 08 LS 460 left me stranded
