Trans drain & fill vs a flush
Alright, so I am a little confused here.
First, my understanding is that our cars do not have a means to "flush" a transmission in the normal sense and that what's involved in the service is that the fluid is drained and then filled to a proper level while maintaining certain parameters (e.g., proper temp, hooked up techstream, etc.).
Calling dealers around to get pricing on the service, some dealers are quoting me a usual $160-$190 to do the drain and fill where, as I described above, they say the fluid is drained and then refilled. But, a few of the dealers that I have called fave been adamant that what they do is not a simple drain & fill, but a complete flush where they hook up "a machine" to the transmission cooler and flush the fluid that way.
So with that, can someone please enlighten me as to whether our cars have a trans cooler and whether such a flush is possible, of if I am being fed a bunch of BS. PS, the so-called "flush" is being quoted as a $230-$290 service (depending on the dealer).
Thanks
Thanks
Yes they have a transmission cooler and yes a full flush is absolutely possible. Every drop of that fluid can be removed and replaced with a fluid exchange machine. It's just a matter of IF you want to do it that way.
But if I'm having a complete fluid exchange done I'd only take it to a Lexus or Toyota dealer because then you'd have a better chance of them using the right type of fluid. Something that is not even close to being guaranteed at an ndepemdent because their machine will have had many different types of fluid flushed through it, there will be cross contamination.
Thanks for the info. These are Lexus dealers that I have been calling.
I find it interesting that some dealers offer this type of a flush and others do not.
Is there are reason to pick one service over the other?
A concern with older vehicles is that a "flush" will dislodge particles and grunge from crevasses here and there and that these may plug something up (eg a solenoid). This has been a particular problem with older RX300s. I've had my RX transmission flushed and had no such problems. I might get my LS transmission flushed at around 50-60k.
I think really the only problem nowadays with an exchange machine is that you are replacing all of the fluid with new fluid, and new fluid has cleaning detergents in it, that's a lot to introduce to some transmissions (especially if it's a high mileage unit that is dirty inside). Then there's a chance something could be possibly clogged when it frees up. There's also a chance that the fluid may have small amounts of clutch material (grit) in the fluid that the transmission is relying on, but both of these examples are for higher mileage units. As long as the unit doesn't have excessively high mileage - and they are using the right fluid with no additional special cleaners or flushing additives - I think these machines are fine. But you have to make sure that's what they're doing because if you take it to the wrong place they'll use a universal fluid, sell you a cleaner, then flush your tranny out and put the wrong stuff in there, then you may run into problems.
Personally I'd just do a simple drain and fill once a year for the next few years to slowly introduce that new fluid and gradually get all that old fluid out. I've never had a problem doing this.
I did flush with my LS last week or so. The dealer used BG machine which I am familiar with since I have used BG machine on ES as well. Cost is $290. They first use BG cleaning agent through the machine and circulate few times. Then drain every bit of fluid that remain in pan etc and fill in through the machine. Since these cars uses WS fluid, its worth spending $300 or so for every 80-100k miles.
