Transmission Leak/Bad Solenoid After Transmission Flush
Had my 2010 LS460 Sport serviced at a local Toyota Dealer which included a Transmission flush. A few days later I noticed some drips on the garage floor. Took it back and the Dealer is indicating that a bad solenoid is to blame and the fix is $1200!! Seems very suspicious that the leak developed right after the flush service. Below are some possible scenarios but I wanted some opinions from the experts:
-Flush loosened some crud that wound up in the solenoid?
-Dealer didn't follow procedure (techstream) and somehow goofed up solenoid?
-Would overfilling cause this issue?
-just frickin bad luck?
Thanks!
Thanks!
I had them do some a la carte service....tranny coolant brake flush, and Oil/filter. Cost around $900 if I recall. Spark plugs were $591 installed...did those myself LOL
As far as the solenoid, I need to get more details from them. They said the solenoid was acting as a pathway to leak fluid down to the pan (originally I thought it was pan leak).
Thoughts?
I agree with Keith....get the dealer to man-up. At the very least they should offer some goodwill gesture...
This was a common issue on the BMW 7 series and X5. Basically it's a solenoid that mounts externally to the transmission and the gasket or solenoid itself can leak. on my 7 series, it cost me 700 dollars at an indy to replace. part was 30 bucks or so. LOL.
How would a bad solenoid cause a fluid leak - aren't they all internal to the sealed transmission? And even if any are external. I don't see how they could cause a bad fluid leak.
Kbueno (05-04-17)
So much for Lifetime fluid!
Call it "Long Life" if you want, but no fluid is lifetime IMHO. Also, understand that only the US market advertises the fluid as lifetime. Likely to compete with other manufacturers that advertise it as such. In Canada and other countries, the requirement is to change every 60k miles (or so) or risk losing your warranty. My manual specifically lists it in the service schedule. For 149 bucks at my local Toyota dealer, it's a no-brainer.
DrQuality (08-06-21)
Lifetime fluid is a term invented by the auto manufacturer not the transmission manufacturer. AF who makes the 8 speed in my Audi has recommended service intervals but Audi calls it a lifetime fluid. Aisin who makes the transmission in the LS also has recommended service intervals but Lexus North America calls it a lifetime fluid. It's marketing BS.
After reading several posts on this forum, I inquired about having the transmission serviced on my LS with 85K but the shop foreman at the local Lexus dealer strongly advised against it. It works fine right now and I didn't opt for an extended warranty so I am inclined to just follow their advice, rather than risk something like this thread happening.
first time hearing this happening to a LS460 8-speed transmission.
they are thought to be robust and almost bullet proof.
I've done 3 times drain & fill on my 09 LS460 during the past 4 months, replacing ~2500ml of WS fluid each time, with help of a temp-gun (46~55 C)
so far so good.
so far so good.
