How to repair "AC Auto kicks off. 2010LS 460
I have read other post on this issue. I opened the cabin air filterer cover, I can see the filter is covered in the down position. I started the car and pushed the recirculate button on and off to see if the flap opens. Nothing and stays closed. Does that mean I need a new Servo Motor and if replaced will it make my AC auto temp work properly and not kick off and I push again and it show 75 degrees on display. If so what is the part number. I can fix things my self and save $1000.00.
Hopefully all you need to do is reconnect the lever which attaches the door to the motor. Mine had the same issue when I bought it, 20 minutes worth of work and it's perfect now. There should be a thread around here with detailed pictures but the lever you're looking for is on the left of that vent door, you'll need to drop the glovebox to access it.
bam
RX - 3rd Gen (2010-2015)
47
06-26-12 08:04 PM
