What should I look for with a used LS460? Common Problems? (merged threads) - Page 5 - ClubLexus - Lexus Forum Discussion
Go Back  ClubLexus - Lexus Forum Discussion > Lexus Model Forums > LS Models > LS - 4th Gen (2007-2017)
What should I look for with a used LS460?  Common Problems?  (merged threads) >
Old 05-30-16, 11:50 PM
  #61
blahsx
blahsx's Avatar
right now im still eyeballing this black ls460l at this car dealership in my area. but my plan is to look at the auction for at least 1-2 weeks before buying from dealership
also can someone explain to me how does vin cut off work
https://www.clublexus.com/forums/ls-...-2010-a-2.html on post#19
blahsx is offline
Old 05-31-16, 05:07 AM
  #62
sapstar66
sapstar66's Avatar
I have a 2010 with 95k miles (about to be for sale) with no-issue-what-so-ever.
Mind you it's a RWD with NO air suspension, so this might make a difference
sapstar66 is offline
Old 05-31-16, 09:27 AM
  #63
gte819s
2010 SWB sport with 57K
upper front control arms replaced at 50K at $3800, covered by CPO. now its popping again in turns.
no other issues
gte819s is offline
Old 05-31-16, 09:51 AM
  #64
litesoarer
no other issues
Not as bad as having an air shock die in 7K miles. Lol.
litesoarer is offline
Old 05-31-16, 10:32 AM
  #65
aeggroup
no other issues
Hi. What are the signs of bad control arms ?
aeggroup is offline
Old 05-31-16, 10:42 AM
  #66
blahsx
blahsx's Avatar
color? and how much? you're not in cali huh
well i guess car wobbles, make noises, and signs of crackings on bushing.
blahsx is offline
Old 06-07-16, 05:18 PM
  #67
aeggroup
So I went to my dealership and complained about front suspension being weak. After inspection they concluded all control arms and sway bar bushings must be changed. So glad I got L/Certified car. Total for that repair is $3,800. So my advice - try to get L/Certified car. It's worth it. I own my car 1 month and CPO price premium paid off already.
aeggroup is offline
Old 06-07-16, 06:48 PM
  #68
roadfrog
roadfrog's Avatar
At over-inflated Toyota labor and parts costs, yes. However, if I ever need the same work done, it will be with aftermarket parts and DIY or independent for 500-800 bucks.
roadfrog is online now
Old 06-08-16, 01:01 PM
  #69
Doublebase
Doublebase's Avatar
Actually what probably happened is as soon as the dealer knew you had a CPO, they changed the control arms. Otherwise you'd take it to an independent and they'd charge you $600-$1000. Any sort of extended warranty turns into a feeding frenzy at the dealer...they see it...they change parts. I guess it's good if you have that warranty, if you don't, you just spend 1/3 at an independent and be done with it. Six and one, seven in the other.
I've owned my 07 LS for two and half years, I bought it with 70,000 miles...I've driven it 60,000 miles since. I've put $750 in parts into it during that time...the control arms and a wheel bearing. I now have 130,000 miles. I anticipate spending nothing for the next two years and 60,000 miles. Wishful thinking? Maybe, but the "major repair" has now been done (the control arms). And the other major repair (the brake actuator) has now been extended under factory warranty until Decemeber of 2013.
Doublebase is offline
Old 03-17-17, 09:18 AM
  #70
UDel
Default What should I look for with a used LS460?
My GS430 was recently totaled so I am in the market for a vehicle. Normally I would not be too interested in a LS as I am still pretty young, though I like bigger nice cars, but I do love the power and smoothness of my V8 and I can't get a V8 in a 4th gen GS, I don't really care for the 3rd Gen GS but I may test drive one again. I am narrowing down my search to a used 4th Gen GS, 4th or possibly 3rd Gen LS, Infiniti M45/Q70, possibly a IS350 though I want more room, 4th Gen Acura TL SHawd(I know with the beak but with a aftermarket grill and the larger wheels I find them very nice looking plus they are generally very reliable, sporty yet roomy, and have the best awd system and the selection is pretty good for them), and last gen RL if I can find one with low miles. Can't do Germans even though some are very tempting, even more so then Japanese, as reliability is my biggest concern when buying a car.
Anyway, I have done some research on the LS460, know to avoid the air suspension models, there are some bushing/control arm issues I need to look further into, but is there anything to really look for or popping up on some older LS460's with some miles on them I need to look for.
UDel is offline
Old 03-17-17, 09:32 AM
  #71
roadfrog
roadfrog's Avatar
Some of those cars you are interested in are not only not V8's but are also front wheel drive. Not sure if that concerns you or not. It would me.
In regards to the Acura, do you research. They have literally fallen off the charts for reliability. I believe they are 17 of the 30 or so manufacturers, mostly due to transmission problems. Shocking, but true.
As for any issues with the LS, the only areas of concern (and even then...minimal), are the noted control arms, water pumps, and the Mark Levinson amp. All of which can be fixed for peanuts. 1500 for CA's, couple hundred for water pump and amp for 6-800. And your car may not suffer from any of them. For example, I only had to replace ONE control arm and one ball joint, I Diy'd my water pump for 60 bucks and my ML amp has never failed me. My 08 has over 190k kms (125k miles?), on the odo and has been the most reliable car I've ever owned (about 20 cars from BMW to Acura to Domestic).
The Following User Says Thank You to roadfrog For This Useful Post:
mckellyb (03-19-17)
Old 03-17-17, 11:48 AM
  #72
teedub21
teedub21's Avatar
While the LS is a big heavy car it actually has some hustle. 0-60 is just under 6 seconds. Should drive one then decide!
teedub21 is offline
Old 03-17-17, 11:49 AM
  #73
sktn77a
sktn77a's Avatar
How about the 4th Gen GS-F - there's your V8 if you don't like the size of the LS.
http://www.lexus.com/models/GSF
I'd stay away from the Infinitys. And the Acura TL, while not as problematic as the TLX, is not really in the same league, even with AWD.
Get the absolute newest LS you can, if you decide to go in that direction.
sktn77a is offline
Old 03-17-17, 11:53 AM
  #74
ragingf80
ragingf80's Avatar
Acura is still above average, but not as high up as Toyota, Lexus or Honda.
http://www.dashboard-light.com/reports/Acura.html
ragingf80 is offline
Old 03-17-17, 12:20 PM
  #75
yumaslim
I'm (potentially) in the market for a 4th gen LS as my 15 year old Jag has some rather expensive problems and just isn't comfortable anymore.
How would I spot these LS issues during a test drive?
yumaslim is offline
Quick Reply: What should I look for with a used LS460? Common Problems? (merged threads)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
