"Try a Toyota oil filter"
Old Oct 16, 2016 | 06:23 AM
jfattibe's Avatar
jfattibe
Originally Posted by NJToany
Regarding the Transmission flush.... Do you feel any difference while driving with the new fluid? Smoother shifting and downshifting?
I don't notice any difference, it's more peace of mind that it's done. He did say that it was pretty black and nasty though.
Old Oct 16, 2016 | 07:59 AM
Chuckinnj's Avatar
Chuckinnj
Originally Posted by Doublebase
I found this peculiar setup online last night, it's used in conjunction with your normal oil filter, it supposedly captures particles so small that no other filter can come close to capturing. It uses a paper element (roll of toilet paper).
I would NOT use a oil filter to wipe my butt........ and I would not use toilet paper to filter my oil.
What's next? Preparation H for stopping wiper streaks??
Old Oct 16, 2016 | 05:28 PM
greg3852's Avatar
greg3852
OP not sure where you are in Ma, but I used to go to Lexus of Warwick until I went to Herb Chambers Lexus of Hingham. Liked them much better. Just in case you ever want a change.
Old Oct 16, 2016 | 05:35 PM
jfattibe's Avatar
jfattibe
Thanks Greg, will keep that in mind.
Old Oct 16, 2016 | 06:28 PM
2v1g's Avatar
2v1g
I will Just get a Toyota oil filter and be done with it
Old Oct 16, 2016 | 06:35 PM
jfattibe's Avatar
jfattibe
Originally Posted by roadfrog
Those filters that use toilet paper are shi**y
roadfrog, I know you stated that when you changed your oil and started using Toyota synthetic that the hesitation went away but what filter are you using ?? Just wondering if the Toyota was any different then after market.
Old Oct 16, 2016 | 09:31 PM
roadfrog's Avatar
roadfrog
I only use Toyota filters.....but only because they're almost the same price as aftermarket. I'd have no issue using anything else if they were significantly cheaper. I've gone nearly 10k miles on the Toyota filters and they were in fine shape when I replaced them.
Old Oct 17, 2016 | 06:35 AM
Lexuslsguy's Avatar
Lexuslsguy
If you are running an extended OCI the Fram Ultra Syntheic line is a favorite among many. 99% filtration @ 20 microns and a silicon ADV. This is what I run on all my vehicles with great success. Way better then the OEM filter and most out there.
Old Oct 17, 2016 | 12:01 PM
superdenso's Avatar
superdenso
Mobil Oil filter now avail: MIC-256
Mobil 1 Extended Performance Oil Filters offer the ultimate protection for your engine – especially when used with Mobil 1™ fully synthetic motor oil.
In fact, Mobil 1 oil filters provide up to 15,000 miles of guaranteed protection when used with synthetic motor oil.
Our advanced performance oil filters use synthetic fibers, which leave your vehicle with cleaner oil and an engine that performs better and lasts longer.
https://mobiloil.com/en/oil-filters/...ce-oil-filters
Old Oct 17, 2016 | 04:28 PM
roadfrog's Avatar
roadfrog
Explain "way better". Keep in mind that those numbers are not far off from pretty much any filter out there. Also keep in mind that there is a balance between flow and filtering. You could make a filter that filters down to 1 micron, but that would mean no flow. Toyota engines are known to go a half million miles on standard filters. Lets not over think this. Your air filter is far more important to engine health than whether you use an OEM oil filter or a cheap Fram.
Old Oct 17, 2016 | 06:04 PM
superdenso's Avatar
superdenso
Default Allow me to explain "way better"
If a company like Mobil gives you a 15k gaurantee, it's better than 5k with no gaurantee Further, a 10k oci should be within reason
Old Oct 19, 2016 | 07:48 AM
jfattibe's Avatar
jfattibe
UPDATE --
Just an FYI, I changed the oil last night to see if the re-flash worked on the transmission, I used the NAPA Gold filter instead of the Toyota to eliminate any confusion. Well, the re-flash worked ! I drove around for awhile trying to get it to hesitate and nothing. What the re-flash for the transmission has to do with the engine, I don't know. All I know is its running great ( for now).
Old Oct 19, 2016 | 07:54 PM
johnnyg66's Avatar
johnnyg66
Thumbs up
UPDATE --
I hope you will be good. I too had the ecu flash in March i did a oil change in Feb had the issue for a week. I did anew oil change in Sept and to date had no issues like i did in Feb.
ssmoked
RC F (2015-present)
26
May 11, 2021 07:07 AM
Dinomon
Apr 12, 2015 07:48 PM
Benzat17
Jun 3, 2011 11:44 AM
xuserx04
May 10, 2009 06:01 PM
coppedl
RX - 1st Gen (1999-2003)
Dec 7, 2005 03:16 PM
