Extending an Extended Warranty
Old Sep 28, 2016 | 06:54 PM
mrcd's Avatar
mrcd
Default Extending an Extended Warranty
Hi everyone. I have a 2008 LS 460L w 64000 miles. All the major repairs done, including the Control arms. Will be coming out of extended warranty in a few months and car still rides like the day I got it. Can I purchase an extension of extended warranty? It was an 8yr warranty. Car purchased in 2009. Thanks.
Old Sep 28, 2016 | 07:29 PM
comotiger's Avatar
comotiger
I am sure you can find a company to sell you an extended warranty. If you are asking whether Lexus will sell you another extended warranty before your current one expires, my guess would be no. You could contact Toby Rivers at Shreveport Lexus about this.
Looks like the car has been really good to you. Do you think you recouped the investment in the extended warranty through the repairs? The CAs can be fixed cheap if they go bad again, so you don't need another warranty for that. Does your LWB have air suspension? Has that been replaced? How about the brake actuator? If these parts are still the original ones, it may make sense to get another warranty, otherwise save your money.
Old Sep 28, 2016 | 10:34 PM
dlbuckls10's Avatar
dlbuckls10
Exclamation
Fairly low mileage for an "08 and I'm sure you can purchase another warranty from several companies but an extension of your present warranty is probably history. Parts will break down or fail and there's nothing cheap about Lexus parts.
Old Sep 29, 2016 | 03:22 AM
mrcd's Avatar
mrcd
Car has been fairly good to me. It has had fuel rails, valve springs, wind noise fix (which worked so-so), brake actuator replaced, water pump, air suspension had to at least be adjusted a few years back-not sure about replacement. All in all, I've had more problems with the car than I expected. But all in line with what I've read here.
I guess I can take to a local mechanic or dealer.
Old Sep 29, 2016 | 08:41 AM
roadfrog's Avatar
roadfrog
Many of those things were covered by recalls. So other than the suspension and water pump, what do you consider "problems"?
Old Sep 30, 2016 | 09:29 AM
mrcd's Avatar
mrcd
Called the dealer about extending extended warranty. Additional 2/24 is $2700. 3/36 is $3550. Pretty cool that I can extend warranty to the 11yr mark.
I did not expect to have recalls such fuel rails, valve springs. Very invasive repairs. Then the others w actuators, air noise and control arms seem to be near universal problems with this car.
I've been very satisfied with the car because of excellent service. if it were not for the superior service I wouldn't have been so happy.
Old Sep 30, 2016 | 10:03 AM
roadfrog's Avatar
roadfrog
Well, I guess I come at it from a different angle. Lexus is covering "potential issues"....not neccessarily a problem...but "potential" problem. That is important to me. On the flip side, look at my previous BMW 7 series. HOSTS and HOSTS of issues that were pretty much suffered by every owner at Bimmerfest. We're talking tens of thousands of dollars for various issues like burning oil due to valve seals. Undersized ports in the engine that caused coke/carbon build up and rendereed cars impossible to pass smog emissions tests unless an engine tear-down was conducted. Coolant pipe seals that were buried inside the engine requiring replacement every 50k miles or so (to the tune of several thousand). Guess what? NOT ONE recall on that car EVER. Be thankful Lexus is going to bat for you.......BMW (and it seems most other "flagship" marques) certainly are not. Fuel rails are not invasive. Valve springs? Meh....not really.
Old Sep 30, 2016 | 03:05 PM
Nospinzone's Avatar
Nospinzone
I dare say most automobile manufacturers would not have done the fuel rail, idler pulley and valve spring recall at all. From everything I could see it was proactive on their part to spare the maybe 2% of owners who would actually experience a failure.
Old Oct 1, 2016 | 05:10 AM
mrcd's Avatar
mrcd
Excellent points that Lexus has stepped up. That's why I'm having such a tough time parting with the Lexus brand. I'm holding out for the remodeled LS. Besides, got 2 in colllege now and Holy Cr@p!! Even when you plan, the older they get the more expensive they get.
Old Oct 1, 2016 | 07:28 AM
Nospinzone's Avatar
Nospinzone
That's true with a lot of other people (I hope my wife doesn't read this) and things too!
vishal73
Aug 31, 2011 12:42 PM
I8ABMR
Sep 29, 2008 09:03 PM
DaSweetgrl
Apr 21, 2006 03:17 PM
