Trunk lid won't go up or down electrically
Check all fuses all good how do I check electric motor
open up the glove box. There is a switch that says trunk opener cancel. Try pressing it an attempt again
Originally Posted by Ls600hl60
(Post 9594860)
If toggling the valet switch in the glove box does not make a difference, then maybe it is the motor. When you open the trunk manually, are there any grinding or clicking noises and/or do you encounter any resistance? Providing this information may allow folks here to help you better. If all else fails, it is time to visit your friendly dealer. |
I have a 08 ls600 hl bought it about two months ago.trunk will release but will not open all the way like it did when I bought it,plus the trunk will not go down automatically when button is pressed. No grinding Tried every thing I know.I have the skills to work on cars so I will pull motor soon and have it tested.
(Post 9597211)
Hopefully you will be able to DIY. I had a similar problem and it cost over a grand to repair but covered under warranty.
Originally Posted by dlbuckls10
(Post 9597288)
Originally Posted by comotiger
(Post 9597328)
Was the cause of the problem a defective motor?
will keep you posted on what I find out about trunk motor.
Check the torsion bar in the trunk.
Originally Posted by MrMark
(Post 9597618)
Is torsion bar connected to brackets on electric motor?
who can tell me the color of silver paint on 19 inch rims,08ls 600 hl. Few scratches
I'd like to touch up |
(Post 9598364)
Trunk lid will raise half way up and stop
| All times are GMT -7. The time now is 09:55 AM. |
