tear in seat 2011
Subscribe
Feb 15, 2016 | 10:03 AM
Any suggestions on how to repair a pretty good tear in my passenger seat its about 1" in length.
Reply 0
Feb 15, 2016 | 10:24 AM
A tear this long should be repaired by a pro...... I don't know where you live in NY but here is repair guy in NJ (just off route 80) that can do it for you. www.platinumcareleather.com OR www.wecanfixthat.com for a shop in your local area. You can always replace the seat cover at a high cost but a 1" tear is an easy fix that can be done by a pro. I do NOT suggest buying a "As Seen on TV" leather repair kit and doing it yourself especially on a seat that gets used everyday. Check with some detailers in your area and see if they can help you if you have a hard time finding a leather repair pro.
TIP! Get the done ASAP while the cut is "fresh" and before it grows.
Reply 0
Feb 15, 2016 | 10:37 AM
I've seen this done on some car programs on TV. Seems the outcome looks pretty good when done professionally and is almost invisible. A good shop is key IMHO.
Reply 0
Feb 16, 2016 | 05:00 AM
Quote: A tear this long should be repaired by a pro...... I don't know where you live in NY but here is repair guy in NJ (just off route 80) that can do it for you. www.platinumcareleather.com OR www.wecanfixthat.com for a shop in your local area. You can always replace the seat cover at a high cost but a 1" tear is an easy fix that can be done by a pro. I do NOT suggest buying a "As Seen on TV" leather repair kit and doing it yourself especially on a seat that gets used everyday. Check with some detailers in your area and see if they can help you if you have a hard time finding a leather repair pro.
tyvm Im on Long Island pretty much dead center *north shore, Im going to call the dealership today and see what they suggest too.
Reply 0
Feb 16, 2016 | 10:20 AM
I feel your pain. I am unhappy about the crack in my driver side door arm rest. It's getting bigger and I need to stop the bleeding. I'm sure your dealer will recommend someone.
Reply 0
Feb 17, 2016 | 11:36 AM
This kit - available at Pep boys or Amazon:
Amazon.com: Loctite Leather, Vinyl and Plastic Repair Kit (86434): Automotive Amazon.com: Loctite Leather, Vinyl and Plastic Repair Kit (86434): Automotive
Reply 0
Feb 17, 2016 | 01:12 PM
Can't speak to repair quality, but color-matching is a nightmare with this kit. You can get close, but for all the effort, I would go the professional route all the way.
Reply 0
Feb 17, 2016 | 02:22 PM
It is what it is...
Reply 0
Feb 17, 2016 | 02:28 PM
Quote: It is what it is...
Indeed it is, Randy. I learned this while trying to touch-up a tiny spot inside my car.
Reply 0
Feb 17, 2016 | 04:38 PM
I wouldn't mess with this on a $50,000 car........... I tried a similar kit on and old chair - what a mess it made!
Reply 0
Feb 18, 2016 | 08:43 PM
Had a spot on the front passenger seat and had it done professionally where they removed the old panel with a replacement and color matched it. Expensive ($650) but worth it.....
The perforated leather pattern needs to match as well..... Looks brand new.....
Reply 0
Feb 20, 2016 | 06:56 AM
Quote: Had a spot on the front passenger seat and had it done professionally where they removed the old panel with a replacement and color matched it. Expensive ($650) but worth it.....
THIS! ^^^^^^^ BEST advice for a flawless repair........ Especially on a "high end" car like a LS.
Reply 0
Feb 20, 2016 | 08:13 AM
I agree...and you can get it done for much cheaper. I'd expect to pay between $150-$200. Where exactly is the tear? Any pics?
Reply 0
Feb 20, 2016 | 08:21 PM
Leave this one to the professionals. Even if it's a few hundred dollars.
Reply 0
Feb 21, 2016 | 12:46 PM
Quote: Leave this one to the professionals. Even if it's a few hundred dollars.
I agree and avoid the cheap repair kits.
Reply 0
Subscribe
