ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   LS - 4th Gen (2007-2017) (https://www.clublexus.com/forums/ls-4th-gen-2007-2017-178/)
-   -   Car won't start sometimes (https://www.clublexus.com/forums/ls-4th-gen-2007-2017/809819-car-wont-start-sometimes.html)
njumongkol Jan 20, 2016 10:43 PM
The car is daily driven and at least once out of the week it won't start. To get it started I have to disconnect the battery to reset it.
When it doesn't start it has these codes:
P0390, P0365, P0345, P0340, and P0335.
When I reset the ECU the codes are gone and then it starts.
Could it be these camshaft or crankshaft sensors going bad at once or do you think it's something else that's connected to it that's causing it not to start?
Batteries good, I changed the starter 8 months ago, and the last thing I had done was a fuel recall that was done at the dealer.
Any input would be greatly appreciated!
Thanks!
isfdude Jan 20, 2016 11:59 PM
Replace those sensors, if it is still doing that you might need to replace the ecm itself. Before doing anything though check for some open wires shorting out along those sensors to the ecm.
R Z Jan 21, 2016 06:54 AM
If the car was starting fine before the fuel sensor recall, take it back to the dealership.
jmcraney Jan 21, 2016 07:01 AM
When you say "it won't start" do you mean that it will crank but won't start, or do you mean that it won't crank?
roadfrog Jan 21, 2016 09:31 AM
Check out this thread:
http://www.justanswer.com/toyota/87g...html#re.v/456/
njumongkol Jan 21, 2016 03:52 PM
no crank or sound at all
njumongkol Jan 21, 2016 04:12 PM
I'll check sensors and thanks Roadfrog for the link!
jmcraney Jan 21, 2016 04:25 PM
Well, that sort of gives me some concern about the battery or the connection to the battery because you indicated that perturbing the battery/connection gets you out of this condition. The battery can test good but still have an internal connection problem that only surfaces at certain temperatures. The battery cable could be defective. You should keep this in mind in case you run out of ideas.
isfdude Jan 23, 2016 08:49 PM
Does the starter make a click sound? Did you check voltage? Maybe a fuse is blown, if not your starter might be dead.
njumongkol Jan 24, 2016 04:09 PM
Starter doesn't make a clicking sound. It's fine now, I drove the car for 4 days now and it starts up every time. Like I said it happens like once a week. It's weird.
isfdude Jan 24, 2016 10:00 PM
Did you replace the battery in the remote key?
isfdude Jan 24, 2016 10:01 PM
Wait I had this problem when the brake switch didn't work right. If the brake isn't applied it won't start.
