What's that sound when i open the door?
My 2009 LS 600h:
I park the car, i turn it off, the steeringwheel goes to park position. Then, when i open the door i hear a sound like a electric motor. What's that sound? My GS 450h did exactly the same. Auto handbrake on or off makes no difference. |
Originally Posted by Higgie
(Post 9166240)
My 2009 LS 600h:
I park the car, i turn it off, the steeringwheel goes to park position. Then, when i open the door i hear a sound like a electric motor. What's that sound? My GS 450h did exactly the same. Auto handbrake on or off makes no difference. -Joe |
(Post 9166240)
My 2009 LS 600h:
I've only had the car ('08 460 SWB) for about a month so I'm still trying to figure the electric motor/servo noises out, but the car makes an awful lot of them shortly after being parked. There's one from under the hood which I think is the evap system, as mentioned. There's also one from inside the dash (blend door?) and occasionally the soft-close doors or power trunk will make noises when not being closed. I do wonder about battery drain since typically my car sits during the week and is driven only on weekends.
Originally Posted by dal20402
(Post 9168104)
Thanks for the tip on the door switches. I'm pretty sure mine are working fine -- I haven't seen any of the anomalous behavior others have reported. The noise I hear from the doors from time to time sounds like it's coming from the soft-close mechanism, not at all like the locks. The manual says that mechanism may activate from time to time when the doors aren't closing and it's not a cause for concern. I just wonder if it happens at other times (when I'm not there) and if so what the impact on battery life is. I know these cars are hard on batteries... every one I looked at seriously enough to examine the service history had multiple battery replacements, including the one I bought, with the most recent just a couple of months before the previous owner sold it.
Well, if you are concerned about your battery, the easiest way to get a grip on that is to monitor the battery's State Of Charge with a voltmeter, checking when you first stop the engine and then again after some extended period. Car batteries have a self-discharge rate of 2 - 20% per month - typically most batteries are closer to 2% per month and you have to take that into consideration.
Here is a temperature compensated SOC table for lead- acid batteries that will give you a good indication of how much you battery's charge is being impacted. It is dependent on having an accurate, high resolution voltmeter but those are available at a reasonable price. I think it is a myth that these cars are "hard on batteries." These are very well designed, stable, automobiles and batteries work the same in these as they do in most other cars. I think the "hard on batteries" reputation is related to the defective doorjamb switches. https://cimg8.ibsrv.net/gimg/www.clu...95360aad9b.jpg |
Prior to opening the door it's pretty quiet! :cool:
I don't know if i'm talking about the same noise, if it is then in the Prius forum we think the car does this to re-apply pressure to the hydraulic brake booster system, getting ready for you to drive; it's totally normal when you open the driver door after a few hours of non-operation.
A reason why this noise got talked about is because it may cause problems during brake works. Otherwise this goes un-noticed. The worry is while the caliper is off, opening the door will trigger this pressuring to happen and might push the caliper pistons totally out, causing lost of pressure and fluid and might trigger a dash full of lights (and a tow to the dealer). Thus Prius owners either disconnect the battery or NEVER open the door when doing brakes, or take it in. |
The noise you hear is the steering wheel lock. You don't have a key so the wheel lock is electronic. You can test this by turning off the car and trying to turn the wheel. It should turn a bit. Open the door, and listen for the servo. Next, try to turn the wheel and you will find it quite stubborn. Enjoy your LS:)
Originally Posted by superdenso
(Post 9170544)
Thanks for solving this mystery :) |
Goodmorning Higgie, you are welcome...we are here to help each other enjoy our purchases. Toyota builds beautiful and reliable cars:)
My 600 does same thing..my car makes noises often. They sound official but sometimes they come out of nowhere lol
(Post 9170544)
Thanks super! My 2010 LS makes this noise. This has bugged me since I got it about five months ago. Your test confirmed it. |
Its the sound of money...
| All times are GMT -7. The time now is 12:03 PM. |
