trouble by changing TPMS IDīs with Techstream and VCI cable
Old May 29, 2015 | 02:27 AM
AndreasMUC's Avatar
AndreasMUC
Default trouble by changing TPMS IDīs with Techstream and VCI cable
hallo,
I need some professional help in this issue:
At my LS460, I need to change the TPMS sensors IDīs. For this, I bought a mini VCI cable with firmware 1.4 and techstream.
I installed it on an old XP notebook and was able to connect to the car and read all ECU and defect codes. I was able to read the actual sensor IDīs - but if I want to change them I got an timeout-error.
The cable check in Techstream shows that K- and L-lines are disabled red. As I read in some articles the K-line is only avaible for older Toyotas with 22-pin connector.
I have a 16 bit connector, but it looks like that reprogramming any issue is done with the L-line.
Is there any Information available if this issue is depending on the Techstream software or the firmware of the VCI adapter?
many thanks from munich
bswhitener
Jun 15, 2023 07:18 PM
hks619
Oct 12, 2018 08:58 AM
Myrix
Wheels, Tires & Brakes Forum
Jul 5, 2016 08:59 PM
meta
Apr 16, 2015 04:04 PM
vietboix
Apr 16, 2015 04:59 AM
