LED Side Mirror Install DIY with pics
One question, do you recall specifically were you attached the ground wire? And were both driver and passenger grounds attached to the same bolt?
Thanks again.
Thanks, and this place did a great job also. I'm probably going to install them today, So I'll post some pictures when completed.
Thanks again.
Thanks again.
I installed the passenger side mirror, but I have not connected the wires yet. Is there a certain spot to aim for in order to get the wire over the transmission well to the steering column section? Also, it seems like my wire may not be long enough because I installed the black connecter in the mirror assay.
Thanks
Thanks
Thanks
Thanks
I had a ton of wire from the passenger side, but just do a mock and run the wire to your driver side footwell and see if it reaches. If not you can splice the wire from the driver side assembly
You can get the wire through the furthest back of the firewall, just poke through with your metal hanger.
I don't know why I didn't think to check the length of each cable before I started the install. It appears that one wire may be longer than the other, but I'm not sure. Can anyone confirm if one wire is longer?Thanks
I'm stuck on trying to get the passenger wire over the transmission. Is the spot near the foot well light wire? Thanks in advance.
Ok, I finally got it. I had to put the hanger from the driver side and pull the wire from the passenger side!
Same year as mine, so wiring should be identical. Do you have a test light? All you need to do is check the wires until they emit the necessary flashes, etc. The wire colors will be the same as the ones I mentioned. I believe that the colors are universal throughout the Lexus lines.
