AC Filter Replacement
Old Sep 28, 2012 | 02:31 PM
EskieFan54's Avatar
EskieFan54
Default AC Filter Replacement
I am trying to replace AC filter on my 08 LS460L and it seems so easy in the instructions. That is if you can get the damn shelf out, I read that if you work at it, it will just slide out. Not mine, I have the AC in recirc but it seems as if there are hidden screws holding it in. I am afraid to really force anything. Am I missing something?
Thanks
Doug
Old Sep 28, 2012 | 04:18 PM
jmcraney's Avatar
jmcraney
Stick your hand under the shelf, palm up, shelf-support-leg between your middle finger and ring finger, and gently then lift up. You will know what to do from there.
Old Sep 28, 2012 | 05:34 PM
OSU's Avatar
OSU
I believe it has to be on recirculate first. I've replaced mine and it wasn't on recirculate and now it takes up to a minute upon start before I can use it. Something with the door hinge.
Old Sep 29, 2012 | 10:15 AM
EskieFan54's Avatar
EskieFan54
Thanks very much for the replies. I did have it in recirc but it took a bit more than gentle pressure. I imagine the dealer really put it in there when they changed the filter last.
Cheers
Doug
Pittsy
Oct 10, 2018 05:44 PM
lexuspower
May 25, 2011 06:38 AM
LS430Lexus
May 1, 2011 08:40 PM
TEXAS83
Jun 11, 2007 03:43 PM
tony woo
Aug 13, 2004 07:54 PM
