Hid bulbs
Not sure if this is in the thread but I did a search and nothing came up. To all guys and girls if any on the CL, if you did change your hid's what color as well as what brand did you all go with. Reason asking, I went the cheap route and bought some so called replacements on ebay but instead of them being d4s they were the universal ones that are slotted for d4s d4c and long story short they did not work they came on then turned off. After examination if you compared the bulbs you can see they are not the same slighlty different from stock. So what bulbs are you all using besides stock..
That I know but that's for led stuff correct?? I just wondering if you wanted to swap your stock 4300K hid what brand did other go with and did it worked correctly. example phillips, garax .......
thanks I got it figured out, a lot of sellers sell the universal d4c bulbs that are universal for d4c and d4s which apparently is not friendly with bulb socket so it must be a true d4's style and not the universal ones, this can depend brand from brand but I noticed that the prong was shorter as well as the the little notch was deeper preventing good contact. Just something to remember. get oems 4300 or 6000k or true d4s and not the universal ones (d4c)
I swap mine out with Garax 6000K., bought them from this CL vendor.
https://www.clublexus.com/forums/clu...ghttrends.html
Our D4S 5000k HID bulbs are great if you do not want to lose too much light output. Keep in mind that 6000k D4S bulbs are rated at roughly 20% less light output than a 4300k D4S bulb. Our 5000k bulbs will have a crisper output than your stock 4300k bulbs. Take a look at this D4S 5000k HID bulb review.
If interested, make sure to use coupon code "CLGB08" upon checkout to save $20/bulb.
Steve
Steve
mwaull
Jun 2, 2006 10:17 AM
