Smoothest Ride: 460L or LS 430 ultra luxury?
Old 06-02-11, 03:18 PM
I8ABMR
I8ABMR's Avatar
I like the way my LS460 rides but it was not as smooth as I expected when I first started driving it. The 22's kind of made the ride quality a little worse, but at 44psi what do you expect.
Old 06-02-11, 03:52 PM
rominl
exclusive matchup
rominl's Avatar
hey since it has gone for worse, lower the car!
Old 06-02-11, 05:26 PM
CJITTY
CJITTY's Avatar
44 PSI??? I have 20s in the Conti DWS tires and roll on stock PSI recommendations, do 22s require that much? your car must roll around like a rock with that much PSI
Old 06-02-11, 05:44 PM
iceman76
iceman76's Avatar
I was wondering the same thing. Seems high to me. Although, I've never put low pro tires on any of my vehicles.
Old 06-02-11, 06:26 PM
rominl
exclusive matchup
rominl's Avatar
imho 44psi cold is too excessive. with the low profile on 22s, imho 38-40psi cold is what i would run. i am running that on my 20s on the gs and when i had my ls460l, that's what i ran on my 22s. at 44psi ride will be affected quite a bit
Old 08-24-11, 09:59 PM
dxn
dxn's Avatar
I had LS430 non air suspension for 7 years and now own LS460L. LS430 gives smoother ride and quieter.
Old 08-25-11, 08:23 AM
GammaLex
GammaLex's Avatar
I hate to say it but the 2004+ UL rides better then the 460 with Air. I dont have air in my 460 but ive driven it enough to compare. The 430 also felt quieter and more solid. My Range Rover with EAS also rides better than the 460. The 460 looks alot nicer inside and out compared to the 430 though, so its your choice I sacrificed the ride for the new body style.
Old 08-25-11, 11:16 AM
larrygust
larrygust's Avatar
I was driving a 2006 430 without air (on new Michelin MXM4's) before I got my 2007 460L with air suspension (Dunlap Sport stock tires). My first complaint was that the 460L did not ride as well as the 430. So I decided something must be wrong with the air suspension on the 460L. I took it in and sure enough, one of the struts on the back was bad (caused the tires to be worn bad). They replaced the strut under the extended warranty and I replaced the tires with a new set of Michelins like I had on the 430. Part of the comparison certainly has to do with which tires are on the cars.
After repairing the air suspension and having the same new tires I would pick the ride on the 460L over the 430. However, there was not that much difference.
Old 08-26-11, 06:48 AM
woppenhe
woppenhe's Avatar
The 430 was smmother and quieter. The 460 is more up to date in terms of electronics, engine and transmission. They are really two very different vehicles.
Old 08-27-11, 12:34 PM
edarte
edarte's Avatar
Location: Vancouver Island, BC -ex Illinois &Toronto, ON
I had a 430 for nine years and now have a AWD LS460 with air suspension. With the suspension set to "sport" I find it firmer and when set on "comfort" a bit too bouncy. But on the middle setting I think the 460 with air is the equivalent of my old 430.
Old 08-27-11, 01:39 PM
woppenhe
woppenhe's Avatar
Of course the tires are important, as are the tire pressures. Although there is a recommended pressure, it seems, according to these forums that there is a wide variation of what is preferred by owners. I like to inflate them a little more than what is recommended. To me the ride is more comfortable and the car is a litle firmer on handling, but everyone seems to have their favorite pressure within 5-10 pounds.
Old 08-27-11, 05:17 PM
eddie_k_
eddie_k_'s Avatar
I had a LS430 UL and it was so smooth til the suspension gave up.
But like woppenhe said, they are two different vehicles...
Old 01-28-14, 08:03 AM
yowps3
yowps3's Avatar
The UZ V8 is practically the smoothest engine in the planet. Glass smooth
The UR V8 used in the LS460 is not as smooth due to certain factors. Mainly Timing chain instead of belt, direct injection, more displacement and less sturdy/sophisticated engine dampers.
I'm not saying the LS460 ain't smooth. It's silky smooth and probably the smoothest, most unruffled car in the market today. But if you rev both the LS400/LS430 and rev LS460 you'd easily notice the predecessor were smoother and they should be considering they have the advantage at being 'smooth'
leisinjp
03-18-19 03:31 PM
davelex
05-09-11 01:40 PM
lexluger71
05-09-07 07:15 PM
IS Pilot
12-27-04 12:27 AM
Nong
05-26-03 07:40 AM
Quick Reply: Smoothest Ride: 460L or LS 430 ultra luxury?
