Wheels
Old May 9, 2011 | 04:03 PM
frotiss's Avatar
frotiss
Default Wheels
Guys can I do 255/35/20 on a 2007 LS460
Old May 9, 2011 | 07:54 PM
ALeX300's Avatar
ALeX300
sure you can! but why..? check out 1010tires calculator
Old May 10, 2011 | 07:13 AM
CJITTY's Avatar
CJITTY
245/40/20 is the recommended plus size for 20" wheels. if you go with a 10" wide rear wheel, you would use 265/35/20 or 275/35/20
Old May 10, 2011 | 11:01 AM
frotiss's Avatar
frotiss
I was told 245/40/20 will rub in the back, so they will go with 255/35/20 the rims is 8.5 would that be a problem
Old May 10, 2011 | 11:27 AM
CJITTY's Avatar
CJITTY
i have 245/40 front and 275/35 rear on my car with 20x10 staggers in the rear and they DO NOT COME CLOSE TO RUBBING WHATSOEVER! I also have all season tires that are not "squared" shape like some tires. They don't know what they are talking about. I have 31 offset wheels which put the wheels a little further out and still no rub. What is the offset of the wheels you are getting, that plays a part. Unless your tires are sticking out past your car, you need 245/40/20 tires..period!
Side note, i was worried at first about rubbing on the inner part of the rear struts, and i have about 4+ inches of clearance between the tire and the strut...also, when the suspension moves, the tires lean in and will clear the outer fender..you have nothing to worry about, seriously!
Old May 10, 2011 | 12:59 PM
frotiss's Avatar
frotiss
the offset is 13
jc11
Nov 4, 2010 12:52 PM
ek9max
Apr 18, 2009 12:02 AM
tnbigdawg
Mar 31, 2007 12:17 AM
mcgong
Sep 1, 2006 11:58 AM
DR.GS
Wheels, Tires & Brakes Forum
Jun 2, 2003 08:52 AM
