Will these wheels fit
Old 10-10-10, 07:27 AM
Earthdog
Earthdog's Avatar
Default Will these wheels fit
Ok I have an old set of wheels from my Cadillac CTS
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
According to a wheel site below is the 2010 LS460
Offset: 40mm
Backspacing: 6.29"
Bolt Pattern: 5-120
I don't truly understand but doing research it looks like the wheels will fit. Is that correct?
TIA
Old 10-17-10, 01:54 PM
CJITTY
CJITTY's Avatar
slap them on there and see...the hub bore on the LS is 60mm, so chances are the caddy is bigger so you may have vibration issues unless you get a hub centric ring to close up the gap. The specs seem to be close though, it may just work
sacstang
01-20-16 01:00 PM
Pushkar
04-03-12 03:59 PM
LIMS407
08-22-11 11:06 AM
Trevstuh
SC- 1st Gen (1992-2000)
12-18-08 11:35 AM
howiedoit
Wheels, Tires & Brakes Forum
12-05-02 08:08 PM
Quick Reply: Will these wheels fit
