We are going to order a few and get these instructions translated. ( I personally hate to buy something, open the box, and cant read a damn word of the instructions).
Banned for repeatedly violating vendor sales rules on our forum
Originally Posted by jpmotdyn
Installation was ok. I first took apart the driver side paneling, come to find out the ECU was on the passenger side. Took me about 30 mins to carefully remove the wood trim, glovebox and lower airbag. The harness plugs right in and i have the controller sitting in my glove box.
aloha from the 808...can u pls post up pics or more details of the installation? i'll be ordering one soon and i was just wondering how you take out/off the wood trim, how you removed the glovebox and what the harness plugged into and how. sorry man, kinda of a noobie when it comes w/the new LS... vr, mikey
The wood trim above the glove box is just held in with clips, when pulling it off make sure you pull it straight off, not angled otherwise the clips will break. Onece you have that off you will unclip the bottom panel underneath the glove box and it just lays on the carpet as there is a light wire ziptied on to it. You will also want to pull off the leather panel that runs along side the passenger seat. This just pulls right off. Then there is a small panel about 3 inchec long which will also unclip, located to the left of the airbag. Drop the airbag by loosening the 4 bolts, which i believe are 10mm. Let the airbag lay on the carpet, but do not unplug it!! Once you have done this there are 3 screws on the top side of the glove box and i believe another 2 below as well as 2 more bolts, i think ( sorry i am writing this off memory) once the glove box is off you will see the ECU and you unplug the 3 plugs and attach the harness to it and the ECU. Then run the wire from that to where you want the controller. I know this was all kinda vague, but maybe one weekend i will take apart the pass side of my car and take pics. The install was relatively easy, i know its an expensive car and i did not want to do it at first but i started poking around and installed it in about 1.5 hours.
I hope this helps, let me know when you do get it and i will be more than happy to help you out.
i thank you and i look fwrd to the pics... if ever u come to hawaii, pls hit me up. i owe u cold beers. your pal, mikey
