Heavy steering
Old May 9, 2026 | 12:44 PM
Prosperben's Avatar
Prosperben
4th Gear
Arrow Heavy steering
Haven changed my steering rack, pinion, and EPS module brand new from Lexus, I did the calibration, yet my 2014 Lexus LS 460 steering is still heavy. What else can I do? Helpful suggestion, please.
Old May 9, 2026 | 12:52 PM
Anfanger's Avatar
Anfanger
You need to be more specific of type of calibration you did.
Old May 9, 2026 | 04:23 PM
Prosperben's Avatar
Prosperben
4th Gear
I have my ASE mechanic do that with his OBD tool. He and Lexus diagnosed the fault as the steering rack and pinion, after which they pointed to the EPS, from which I bought the parts brand new from Lexus. So to answer your question, he calibrated it with his computer tool, and the steering vibrated during the process. I drove it for a week, and the alert came up again, "check power steering system."
Old May 10, 2026 | 05:34 AM
Anfanger's Avatar
Anfanger
What were the errors codes before and after rack replacement?
Old May 10, 2026 | 03:06 PM
Prosperben's Avatar
Prosperben
4th Gear
Not codes, except a pop-up from the dashboard saying "check power steering system." Have your vehicle checked by a dealer. This is all I get before and after vehicle repair.
Old May 10, 2026 | 03:45 PM
Gerf's Avatar
Gerf
Sounds like you took it to the wrong mechanic, if there were never any trouble codes it would be interesting to know what the logic was behind the decision to replace the assembly…then of course the module was next, I wish you luck.
Old May 10, 2026 | 04:12 PM
Anfanger's Avatar
Anfanger
If you get "Check power steering system" there is always an error code. The issue is only a few error code readers can access the power steering module. Get Techstream and get error codes otherwise it is a waste of time and money.
Old May 11, 2026 | 09:34 AM
There has to be an error code, it will tell you where on the control system or hardware the problem is thought to be by the car.
Old May 11, 2026 | 12:31 PM
Prosperben's Avatar
Prosperben
4th Gear
I get it, and I understand your point, but both Lexus and my mechanic pointed at the same parts for replacement. Here's the code my mechanic sent me: C1532 EHPS. Before starting to change any parts. Thank you for your contribution. I appreciate it.
Old May 11, 2026 | 01:13 PM
Okay well that's the control module, check the torque sensor connector at the for water intrusion first though and al other connectors as any water will screw with the system. I've seen 3 with water causing issues
CFAI
GX - 2nd Gen (2010-2023)
Feb 19, 2025 04:01 AM
jaydeep999
Mar 24, 2024 11:18 PM
Slapchop
RX - 3rd Gen (2010-2015)
Oct 23, 2023 07:53 PM
WILLIAMBLR
Jul 1, 2018 03:08 AM
TheMole
GS - 1st Gen (1993-1997)
Oct 24, 2009 10:40 AM
