Need Help hooked up battery cables in reverse
Old Mar 11, 2023 | 09:19 AM
derreckla's Avatar
derreckla
Default Need Help hooked up battery cables in reverse
LIke an idiot today high on too much caffeine I hooked up battery cables backwards on my 2010 LS460 now I am getting all kinds of lights and problems. Car does start though but won't drive
I read elsewhere to check the main 120 fuse, Does anyone know where I could locate this fuse? Any other suggestions?
Thanks in advance for your help
Derreck
Old Mar 11, 2023 | 09:48 AM
swfla's Avatar
swfla
The fuse box under hood holds many affected fuses. There should be a fuseable link driver side kick panel as well. A tedious process, but check all fuses. It could also affect the alternator. Bummer.
Old Mar 11, 2023 | 12:08 PM
Anfanger's Avatar
Anfanger
Have you tried erasing codes to identify permanent ones?
Old Mar 11, 2023 | 03:39 PM
derreckla's Avatar
derreckla
Thanks for your reply
Old Mar 11, 2023 | 04:40 PM
derreckla's Avatar
derreckla
So I ran the tester on some fuses and leaving the what I believe is the Fusible link box it gets the full voltage but when I hooked it up to these three wires I get ZERO. From what I was reading about other cars theres fuses under here for the alternator etc...
Can anyone verify? or help?
Thanks
Old Mar 11, 2023 | 05:12 PM
Anfanger's Avatar
Anfanger
You might have to replace the entire box (at least, I believe that is the box) as it is not repairable when it fails.
Old Mar 11, 2023 | 05:41 PM
derreckla's Avatar
derreckla
Does this mean it failed?
Thanks
Old Mar 11, 2023 | 05:43 PM
Anfanger's Avatar
Anfanger
It is possible, there was a thread about the fuse box that had to be replaced. I recommend checking it out.
erx4
Dec 29, 2020 08:18 PM
waxman
Sep 9, 2020 09:17 AM
Bimsimack
Sep 13, 2018 01:15 PM
moparmiami
Mar 5, 2016 11:03 AM
smokedawgs
RX - 1st Gen (1999-2003)
Apr 25, 2008 10:05 AM
