Help, front driver side wheel/suspension wobble
Old Mar 8, 2022 | 05:34 AM
PilgrimLS's Avatar
PilgrimLS
3rd Gear
Default Help, front driver side wheel/suspension wobble
I’ve been chasing down some movement/noise coming from my front L front wheel/suspension. best I can describe is a harsh vibration all the way up the steering column when hitting even small pot holes. And also a steady wobble around 70mph. If I hit a pothole on the highway on that side, it shakes the steering wheel pretty violently. It feels like something is loose in the suspension but I’ve been under it and over it multiple times and mechanics have too with no luck finding anything loose. Here’s what I’ve fixed or replaced so far:
- Wheels and tires balanced and rotated.
- lower ball joint
- outer tie rods
- alignment
- asked mechanic to do inner tie rods but he said there was no play so no need but still couldn’t pin point my problem. He thought it was something in the steering column but nothing happens when I hit a pothole on the R front tire and zero vibrations from that side.
I doubt it but could this be a wheel bearing even without any droning? I’m at a loss and tired of trying things.
Any input greatly appreciated.
Old Mar 8, 2022 | 12:02 PM
pmesfun's Avatar
pmesfun
Probably a bad strut or lower control arm bushing.
DMPesso
Suspension and Brakes
26
Apr 28, 2015 06:24 PM
SFFD785
RX - 1st Gen (1999-2003)
Mar 27, 2012 12:06 AM
cmotomn
Jun 12, 2009 10:04 AM
girlilove
Sep 21, 2007 04:34 AM
510alex
Apr 1, 2007 03:31 PM
