180k service cost?
Old Feb 13, 2022 | 04:33 PM
RushNatU's Avatar
RushNatU
Default 180k service cost?
Whats the going rate for a timing belt, water pump service at the dealer vs Indy?
I got a quote for $1800 at my local Lexus…
Old Feb 14, 2022 | 07:23 AM
Romanova's Avatar
Romanova
Should be able to get it for around $1200. Some people will say buy your own parts but most shops don't want the hassle of dealing with that. Just make sure the shop uses the Aisin kit. Call around to find a local Toyota/Lexus/Japanese indy... there is nothing complicated about the timing belt service so a good tech shouldn't have any issues.
At that mileage, I'd want the belt, water pump, pulleys, tensioner, serp belt with pulley & tensioner, thermostat, coolant flush, new radiator hoses, and a front crank seal. Good time to check your valve cover gaskets, cam seals, spark plugs, etc while everything is apart. If the radiator hasn't been replaced, I'd do that also since it's cheap.
Good luck.
mafpolo
Oct 17, 2019 09:31 AM
johnsfe
Nov 4, 2012 10:08 PM
aespea
Feb 19, 2011 12:38 PM
hlb
Jun 7, 2010 02:08 PM
rgarjr
Jun 1, 2004 07:06 PM
