New oil dark after starting engine once
I accidentally putted to much oil into my engine wile servicing it so I decided to take some of it out.
I was shocked because the color of the oil was deep black. I putted it in a plastic bottle and I could hold my phone LED behind it but it has 0 transparency.
Can this be normal? Engine only has about 70k miles.
Oil change every 13,000 miles? That's a pretty long stretch for OCI especially if you make lots of short trips. Even with full synthetic I change oil every 6-7k miles, although many folks go up to 10k miles.
The new oil will look clear/clean after an oil change for a while if; 1) you take the time to allow a full drain meaning no more drips from either oil pan drain or oil filter mount point, 2) the car is jacked up into a position where the engine drains completely. Some vehicles when jacked up at certain angle may not fully drain every last bit of oil.
Well, dirty oil means it's doing it's job with it's detergents. I would shorten your oci and see if it helps. What kind of oil are you running?
That was even way darker and polluted.
Mrslady (03-31-21)
Send a sample to Blackstone Labs. They'll give you a full analysis of whats in the oil. I used them every couple of years with my old Volvo 740 Turbo just to monitor the health of my engine. https://www.blackstone-labs.com/prod...ree-test-kits/
13000 Km or 13000 Miles?
I change mine at 10000 Miles only because I mostly do motorway miles. Sounds like you need more frequent oil changes.
I've always used https://www.theoillab.co.uk/product-...y/oil-testing/ but after Brex****, you may want to find a company in the EU to analyse your oil.
Do you know the price for that oil check?
I've heard there are many affordable LS430's in the UK. Do you happen to know a scrapyard where I can find parts?
Super Moderator
One issue is that the prior owner decided to neglect it so there may be residue that is being cleaned off with the fresh oil. I'd suggest draining it again and use a fresh filter as well. I'd also be suspicious and have the differential, transmission and brake fluid serviced too.
Tranny has new oil.
