Code P0456
Old Aug 25, 2020 | 07:58 AM
CandorBear's Avatar
CandorBear
Default Code P0456
Hey y'all,
my 2003 LS430 base model is throwing code P0456 "evaporative emission system leak detected (very small)". The VSC and check engine light also came on.
This just happened this morning 8/25/20 and from the bit of research I've done it seems to be a vacuum leak on Lexus and Toyota.
if anyone has more information on how to DIY fix this issue your help is greatly appreciated!
Sincerely,
CandorBear
Old Aug 25, 2020 | 08:10 AM
bradland's Avatar
bradland
Replace the gas cap.
Old Aug 25, 2020 | 09:18 AM
CandorBear's Avatar
CandorBear
Bradland, can you explain how the gas cap effects the vsc?
Old Aug 25, 2020 | 10:00 AM
bradland's Avatar
bradland
The VSC light can illuminate for a variety of reasons. Most commonly when the battery is weak or dead. This doesn't necessarily mean there is something wrong with the Vehicle Stability Control system.
Most of the time is simply meas the VSC system has been turned off and won't work until the check engine light, in your case Code 0456, is fixed.
Old Aug 25, 2020 | 11:36 AM
rkw77080's Avatar
rkw77080
As Bradland said... Most of the time, the gas cap is the culprit for EVAP leaks.
Old Aug 27, 2020 | 05:29 AM
infojunky's Avatar
infojunky
https://www.clublexus.com/forums/is-...evap-leak.html
Also check the small hoses underneath engine cover.
Arcturus
Mar 30, 2019 06:45 AM
paulito
Feb 4, 2019 09:48 AM
dadewi
GS - 1st Gen (1993-1997)
12
Oct 22, 2018 12:45 PM
Lexmember
Mar 28, 2017 01:45 PM
Anduran
RX - 1st Gen (1999-2003)
Aug 19, 2012 05:53 PM
