Battery Drain - Driver side Rear Door(Window, Locks, Light)?
Old Mar 30, 2020 | 06:47 AM
checkler's Avatar
checkler
Default Battery Drain - Driver side Rear Door(Window, Locks, Light)?
Had some battery drain issues, tested fuses and found that Fuse 34 (20AMP) RR Door LH - Circuit is: Power Door Lock system, power window, door closer system, door courtesy lights. Pulled the fuse and so far so good. Of course this means that there is no power window, door lock or the puddle light for that door and that isn’t a long term solution.
My car doesn’t have door closer system, so I can rule that out. Anyone have a similar problem with either rear door (driver or passenger)? Ideas on how I can further troubleshoot to determine which system is causing the issue? Will it require taking the door apart?
BigTurtle
Jan 7, 2018 07:53 AM
pmarr
Jul 20, 2017 06:54 AM
mekelly
Apr 9, 2015 10:44 AM
cmasten
May 9, 2012 07:18 AM
akazemi
Jan 25, 2005 06:16 AM
