Oil Level Sender Location
Old Nov 26, 2019 | 05:52 PM
lvfstde's Avatar
lvfstde
Unhappy Oil Level Sender Location
Hey whats up guys, so i had my wife take my 2001 ls430 into get inspected before i do any heavy modding and it becomes a pain in the a** to work on and they told me that my OIL LEVEL SENDER,CRANKSHAFT SEAL, and OIL PAN GASKET were all leaking. However he told her that the oil level sender was on the side of the engine but not specifically where. i tried looking it up and i have found the location being under the intake on a few other Lexus's however none for mine. Could anyone shine some light for me. TIA
Old Nov 26, 2019 | 06:33 PM
Bocatrip's Avatar
Bocatrip
Driver’s side. Not sure the exact location but not totally easily accessible. Be absolutely sure what’s leaking before starting to remove things. I had oil leaking onto my oil pan area. We thought it might be the oil pan and rear main as well. Turns out it was the dip stick o ring, and the oil sender unit, not the oil sender seal. The pan seal was fine and so was the rear main. You need to fix one part at a time to be sure where the oil is coming from. FYI.... The oil pan seal is a real pain to do. The upper pan is a monster job but not as common. Good luck.
Old Nov 26, 2019 | 07:05 PM
rkw77080's Avatar
rkw77080
Old Nov 26, 2019 | 07:42 PM
lvfstde's Avatar
lvfstde
Originally Posted by rkw77080
thanks!!!
Old Nov 26, 2019 | 07:43 PM
lvfstde's Avatar
lvfstde
sounds goood thanks man
Old Nov 27, 2019 | 08:39 PM
mykvr6's Avatar
mykvr6
I've got a leak coming from a similar area, trying to figure out where its coming from. It ends up on the pan and dripping off but I think its coming from higher up like the oil dipstick oring or the level sensor. I'm going to try to get under it this weekend and try to get a good look up there.
Old Nov 28, 2019 | 08:37 AM
Bocatrip's Avatar
Bocatrip
The dip stick 0 ring is more common than most are aware of. . That little 0 ring gets super brittle and leaks. I saw mine after it was removed and it was like a fossil. The 0 ring is also in a precarious place and removing the dip stick filler tube is a chore. The oil level sender can also cause leaks. Since oil leaks get blown around with the engine and air currents, it's best to narrow each one down before proceeding. Wash everything down thoroughly and after a few hundred miles look at it carefully. You'll probably need a mirror to see it closely.
Sactolex
Dec 18, 2015 06:00 PM
Graveyman
Mar 23, 2015 07:56 PM
jbobst
RX - 1st Gen (1999-2003)
19
Feb 2, 2010 12:43 AM
bguild
GS - 1st Gen (1993-1997)
14
Jul 19, 2007 06:29 AM
