DIY LS430 VSV (VACUUM SWITCHING VALVE) for EVAP cleaning / replacement procedure
#31
Update on the EVAP valve.
Still highly impressed about cleaning the valve with wd-40. As a reminder, I do not know whether other cleaners / solvents do the similar job with similar results, but I should say that in my case the EVAP issue was definitely present in my car and was NOT detected by ECM. My acceleration and driving pattern remain the same as well as fuel consumption benefits.
We need more feedback on cleaning this valve with Wd-40 to officially recommend this procedure as a maintenance procedure for high mileage ls430. If anyone have performed this diy, please share your thoughts whether it helped or not.
Bocatrip (06-16-19)
#32
Wanted to add my data point for reference. Had some extra time tonight and thought I would clean my VSV, even though I only have 85,000 miles.
I'm kind of shocked and what a difference it made. I thought my car was quiet and smooth before, now I have a hard time knowing it's on while idling, and there is practically zero vibration or engine noise even when driving.
I only had the opportunity to drive around my neighborhood at around 25 mph so far but I'm very impressed at the difference. Will report back on any change in MPG and freeway speed performance.
The only change I made to the DIY was to use PB Blaster as I didn't have any WD40, but it is an acceptable substitute.
Great recommendation and write up!
LowkeyLS (06-20-21)
#34
Question on this, do Lexus ECUs "relearn" themselves after a battery disconnect? IE a soft reset type deal? I work with Subaru's primarily, and with a battery disconnect, the vehicle "relearns" its idle, etc post re-connection, and it feels like new again. Just wondering if that phenomena plays into this preventative maintenance job at all. The fact that after a few days, OP is still seeing a difference makes me think this might truly be valuable.
#36
Its also amazing how quickly Lexus responds to the change of evap and fuel pressure. It makes me think that emission control is precise and can affect / improve engine performance in every possible way.
#37
its been more than 2 weeks since I cleaned the valve and I am consistently observing the same result.
#38
I'll also add that after my first longer drive (~25 miles), car is still running very smooth. I did not see much of a difference in MPG, although I never had an issue before (typical 26-27MPG on freeway drive) but maybe a tick better MPG after the cleaning, but really the main take away from my cleaning is the smoothness and quietness increase, and this was coming from and already smooth and quiet car.
The very minor vibration at idle is completely gone and even my wife, who couldn't care less about cars, even was shocked how quiet and smooth the car was when idling.
For those wondering, it really is a 5 minute cleaning, then just letting the valve sit to dry out...easy enough that there is practically no reason not to do it when doing other routine maintenance.
#40
Does cleaning the vsv has as much of an improvement as replacing the fuel pulsation dampers? I just replaced mine and felt the car become much smoother and would like to see if cleaning the vsv can make it even smoother
#41
Properly cleaning VSV may stabilize the vapors pressure as well as replacing fuel dampers stabilized your fuel lines pressure. Ideally, it brings the benefit, however, only if your valve was dirty and required maintenance.
#42
OK, so I cleaned out the valve today with WD-40. The hoses held up fine, but...the electrical connector completely disintegrated and the pins pulled out of the connector! I managed to just push the pins into the connector and tried to hold them on with zip ties. How do I fix this? Can I order just the plastic connector piece and reuse the pins, or do I have to splice in brand new wires?
I'm so bummed out right now
Note: the car started right up with no CEL or anything, but I haven't driven it yet
#43
If you don't have a Lexus dealer near by, or even if you do, any Toyota dealer can order them.
LowkeyLS (06-20-21)
#44
Edit: I have an 2001 if it matters
#45
I can't see the severity of your situation but here's a good link- https://www.clublexus.com/forums/ls-...-write-up.html
