Differential assembly to be replaced (2004 LS 430)
Did anyone have a chance to replace rear differential assembly? Mine is damaged and the dealership recommends to replace and their asking price is over $4000 with a used one. I am told their price for OEM costing 2k more. I will need to see if any local shop can do it at a reasonable cost. Any thoughts or suggestions would be appreciated. Thanks.
Sorry to share that mine is a rarity. Mine was leaking right after purchasing back in Dec. 2017 and I had the dealership fix it. They changed differential oil after replacing pinion seal. Not sure what happened. I only drove about 40k miles after differential oil changed.
Thanks much. It looks complicated..The dealership says about 8-9 hours job. I am not sure at this point if I can do it myself. Don’t have time to repair. I am looking for a used part so that a local technician can install at a reasonable cost. Hope it can be replaced less than $1000. What do you think? Also what is the best place to buy the part? After having this issue, I came to conclusion that LS 430 2004 may not be reliable as we thought. I think we may be biased because of the rumors. How can I support reliability of LS 430 when non maintenance items such as a differential assembly gets to be replaced? I am losing confidence...
If you have a written estimate, redact your personal.information and post it.
I purchased a like new differential.with 40,000 miles fpr my 1999 LS400 from California with shipping to Chicago cost me $250.
I have sourcing on a used LS430.differential from 2001 LS430.with 160, 000 miles.
Quite possibly you can locate a donor vehicle with less mileage.
The question is with aged rubber seals and FIPG..should they be replaced whether low miles or not.
How was the differential damaged? Can you provide any details?
As others have posted above this is a rather worry-free part on a 430. Even when the fluid isn't changed they almost never fail. When it does happen it's usually the ring and pinion that endures the damage. They are designed to be replaced while keeping the differential assembly intact. A brand new Lexus ring and pinion (internet price) is a little over $900 but it's not a job for a shade-tree mechanic. Find a shop you can trust who stands behind their work. You can prob find them used at a salvage yard...
https://www.mylparts.com/oem-parts/l...QtM2wtdjgtZ2Fz
Complete carrier assemblies are all over eBay for anywhere from $100.00 to $200.00 plus shipping. Replacement is no big deal and most you'll need is axel seals. Most shops can do this in a couple of hours.
Be sure to get the front and rear bushings. Usually they come installed in the carrier.
Most of the photos I saw indicated very little wear. A quick look at the rubber U joint (propellor shaft) mount indicates condition.
Go to Wal Mart and buy two quarts of their full synthetic gear oil. Put that in the carrier.
Should be able to do the whole deal for $600.00. I'd do it myself for a lot less.
Loren
Loren
Loren
Loren
THIS seems to be the way to go...
Yes, it is my personal view about LS 430 given the following items: all 4 wheel bearing assemblies replaced because of whining noises when move, front Drivers’s door lock not working since 2 months ago, exhaust heat shield starts rattling a month ago, differential problem. I know this is a very old car and I understand age related issues.
Please share the name of dealership that quoted $4,000 for installing a used differential.
Loren
Loren
Thank you all for responding to my inquiry. I do not think I will repair as my wife wants me to get a new car and stay away from repair problems. Wasting too much time. I am not enjoying with this car. That is for sure now. I will see what brings tomorrow. Again I appreciate you all who kindly taking time sharing rich knowledge. That is the wonderful but important benefit of this auto forum.
