Headlight alignment issue, wonky eyeball.
Problem. The drivers headlight (regular not high beam) is aimed significantly higher than the passengers side. Co-worker driving ahead of me in a lifted truck pointed it out to me. (text me to "fix your damned headlights") At home shined the light on the garage door and there is a huge difference.You can physically see that the light "eyeballs" are at different levels. When turning the car on in the morning I noticed that the headlights did there sweep up and down so I am assuming that the motors are working. I am fairly handy so I can fix the issue when I know what is wrong. I just don't understand how this system works. There are some great posts on here about replacing the individual components just hoping to have someone tie it all together or link the manual.
Questions: So do I need to adjust the headlight or is it a sensor? Where are the sensors located? I know there are 2, don't know locations. Does anyone have a digital manual for the car? I know I bought one for a honda and it was great. |
Originally Posted by simpson227
(Post 10495226)
Here's a nice write-up if you decide to DIY...
https://www.clublexus.com/forums/ls-...eup-w-pix.html |
Originally Posted by rkw77080
(Post 10495236)
The plastic gear may be stripped.Once you get into it you will find whats wrong.
