Steering rack issues
Old 08-21-18, 05:56 AM
kenaston99
kenaston99's Avatar
Default Steering rack issues
Has anyone else experienced leaking power steering fluid from their rack and pinion? I have a squeaky noise coming from the rack when I turn the wheels.
Old 08-21-18, 08:29 AM
aufenscuht
aufenscuht's Avatar
Time for a rack sir! Maval makes good aftermarket parts. Stay away from A1 Cardone. They are about 90% of the market.
Old 08-21-18, 08:34 AM
kenaston99
kenaston99's Avatar
Damn, good thing you told me that. I was planning on buying cardone. Do you know if the maval rack includes the seals and Bellow?
Old 08-21-18, 08:57 AM
bradland
bradland's Avatar
I have a SLOOOOW leak in mine as well on the pass side. I put half a bottle of Lucas stop leak into the PS system and it actually worked. Knowing this is only a temporary fix I have shopped around a little, the BBB Industries rack at Rockauto comes with a 3/36 warranty for under $250 after core exchange.
Aufenscuht please share your thoughts on why you feel the Maval is the way to go...
Old 08-21-18, 09:25 AM
kenaston99
kenaston99's Avatar
It's funny you mention that, I just bought some and can't wait to test it out. I've heard good things. I was also looking at the BBB one and am wondering what the differences are.
My mechanic also said I need to replace my resovoir because its black and dirty and you can't see the liquid
Old 08-21-18, 09:40 AM
bradland
bradland's Avatar
As long as the reservoir isn't leaking there's no need to replace it. It's about $200 from Lexus. They all darken with age, some here have had luck removing it to clean inside, but the cap still has a dipstick. Personally I would replace the reservoir mount before even considering the reservoir. The rubber bushings on the mount harden with age thus no longer absorbing slight movements (motor mounts) from the engine. This creates stress on the hose (it becomes hard and brittle as well) from the reservoir to the pump. You will probably notice the hose ends attached to the reservoir are a little wet as all the parts mentioned are no longer flexing as they once were...
Old 08-21-18, 09:42 AM
kenaston99
kenaston99's Avatar
Makes sense. The hoses as far as I know have never been replaced. Should I have that done?
Old 08-21-18, 09:56 AM
bradland
bradland's Avatar
If they show any signs of leaking then yes now is a good time if you are having other PS components serviced.
If they are still clean and dry, but brittle I'm sure, it really depends on your level of OCD...
Old 08-21-18, 09:57 AM
kenaston99
kenaston99's Avatar
Thank you for the information! Im just gonna have them replaced, I don't want to risk anything.
Old 08-21-18, 10:13 AM
bradland
bradland's Avatar
YODAONE created a post on the 400 side discussing this. The parts are different but the design is basically the same...
https://www.clublexus.com/forums/ls-...-bushings.html
Old 08-23-18, 10:12 AM
aufenscuht
aufenscuht's Avatar
*SHOULD* Every time I order one it is complete!
1st250
06-22-21 04:41 PM
jim7485
11-30-15 04:28 PM
Farino81
Performance & Maintenance
06-08-09 11:14 AM
Luxor
Maintenance
01-21-07 10:36 AM
AzSc4
Suspension and Brakes
12-22-06 09:48 AM
Quick Reply: Steering rack issues
