Is the gas cap suppose to click?
Old 05-23-18, 08:01 PM
awesomefar
awesomefar's Avatar
Default Is the gas cap suppose to click?
My check engine light is on and I know the gas cap is a common fix all sources say the cap should click but mine doesn't.
Old 05-23-18, 08:18 PM
StanVanDam
StanVanDam's Avatar
Yes, the gas cap is supposed to click, and clicks more than once if you keep turning. You are supposed to tighten it until it clicks several times. If it doesn't click at all, consider it defective. Sounds like you need a new one, and probably best to go with OEM instead of aftermarket.
Old 05-23-18, 08:46 PM
Jabberwock
Jabberwock's Avatar
yes ..gas cap working properly is supposed to click.
Old 05-24-18, 04:54 AM
Johnhav430
Johnhav430's Avatar
Yes, just once....not like some cars where you can keep turning and clicking indefinitely....
Old 05-24-18, 06:45 AM
Gronemus
Gronemus's Avatar
I think the appropriate course of action is to stop by your local AutoZone or equivalent and get your code read. You're just wandering in the dark otherwise...
KassuX97
KassuX97's Avatar
What code do you get and do you have any symptoms?
Old 05-24-18, 06:14 PM
LS430inDE.
LS430inDE.'s Avatar
Nope.
Not trying to split hairs, but our LS gas cap CLICKS (multiple times) when you've turned/closed it properly, clicks like a ratchet. Ours DO keep turning and clicking indefinitely. It even says on the cap to turn/close until it clicks.
As you mentioned, there is the other type that just clicks ONCE regardless how tight you try to turn, but our LS's have the ratcheting CLICKS when sufficiently closed/tightened.
Old 05-24-18, 06:18 PM
LS430inDE.
LS430inDE.'s Avatar
That's not the litmus test/universal indicator to identify if the cap is working properly. Clicking does not equal a 100% guaranteed good cap.
The clicking is only letting you know the ratcheting mechanism is engaging and you've tightened the cap enough. There could be a deteriorated seal or some other malfunction with the cap. As others stated, get the code(s) read and go from there!
Jabberwock (05-24-18)
Old 05-24-18, 07:05 PM
Romanova
Romanova's Avatar
OEM gas cap
Old 05-24-18, 09:11 PM
jayclapp
jayclapp's Avatar
Originally Posted by Romanova
I'll endorse Bell Lexus of North Scottsdale, AZ.. Also, I'd get an OEM gas cap if one is needed. My 04 gas cap is original and perfect. It will click once and it is tight enough that you won't ratchet to the next notch.
Old 05-25-18, 06:18 AM
Johnhav430
Johnhav430's Avatar
Originally Posted by LS430inDE.
Nope.
If this is the case, then mine has been replaced, because it only clicks once. I assumed it was factory, it looks old. My wife's GM and my Maxima click indefinitely, just as the LS430 oil cap does (no other car I own does that). BMW clicks once, as does my LS430.
Old 05-25-18, 10:33 AM
bloomwcjkl
bloomwcjkl's Avatar
Spend $15 on a code reader on eBay or Amazon. They have bluetooth ones now that can stay connected to the port and send codes to an app on your phone.
1/1,000 chance that a check engine light is a loose gas cap.
Old 05-25-18, 02:03 PM
LS430inDE.
LS430inDE.'s Avatar
WOW. You're giving .1% chance the code is from the gas cap? I'd take you up on that one. OP even stated his cap doesn't click, at all. One thing's for sure, he needs a new gas cap. (Where can I place my bet? )
Old 05-25-18, 02:27 PM
Gronemus
Gronemus's Avatar
A lot of assumptions being made in this thread. I'd take Bloom's side on that bet.
BTW, my 2004 gas cap does not click and I have not issues with any trouble codes for the 18 months that I've had the car...
Old 05-25-18, 11:19 PM
awesomefar
awesomefar's Avatar
I don't know if this is true but I read that some code readers messes with the car if it isn't tech-stream?
Quick Reply: Is the gas cap suppose to click?
