Timing Belt Finished And My 1st Oil Change!
I finished the TB change on my 2005 today. I started it yesterday late morning and got everything taken apart and ready for the new water pump/belt by 4pm, and decided to call it a day.
Got back at it today around 1030 this morning and was finished by 3pm.
Pretty straight forward with no surprises. I used the step by step instructions from the FAQ page as a guide and it worked out flawlessly. The Aisin kit worked out perfectly. I decided to re-use my serpentine tensioner and idler pulleys since the car has low mileage (59,000) so, that leaves me with parts for my 2001 when I do that one in June... Can't wait...
Anyway... On with the show...
Here's the car up on jacks, just getting started.
Once I got it opened up, I started draining the radiator
Next was to start disconnecting the hoses and trans cooler lines, and get the radiator out of the car
Then it was following steps to open up the front of the engine and expose the belt
Here's the engine ready for the new water pump and belt
The water pump looked new. It really did. The only thing worth noting was a build up of hardened coolant (?) in one of the passages. Not sure what else all that hard Pink stuff would have been..
Oh, and John - it is a Plastic impeller on these pumps. Both the old and new pumps were the same.
Here's the new belt installed and starting to put ancillaries back on
Closing it up....
Here's a rare shot for me... Doing my own oil change !!
I usually take the cars to the dealer for the oil change since it's a good deal for the amount of work that's accomplished, but since it was due for an oil change and the car was opened up, I figured I would just knock it out now...
And finally all closed up and ready for the next 90K miles...
The All-Important sticker...
The Crank Pulley was fairly easy to get off. I purchased the Schley Tool via eBay, which was worth it's weight in gold. I was able to slide it right off the crank without using a puller..
And everything else went really smoothly. Leaning over the engine bay got old after 4 hours, so that's why I called it quits on Thursday afternoon...
I'll be feeling this for the next few days now...
Closing it up....
The following 3 users liked this post by 2KHarrier:
2KHarrier (05-27-18)
So, what was the condition of the old timing belt?
Woops... Forgot to add that photo !!
New Mitsuboshi Belt is on the right, old Toyota Belt is on the left. It really didn't have much wear at all. No doubt I could have let this go for a few more years,, but I figured, peace of mind and all that...
The radiator was slightly dirty, but not too bad, so I just gave it a quick vacuum and blowout with my shop air.
Jabberwock (04-27-18)
Now that it's been through a couple Wisconsin winters, it's got a little Patina on it unfortunately...
Nice job and way to save yourself $550. That's what I paid in labor here a few weeks ago on on my LS 400.
Mine was the original TB, WP etc. I used OE parts which was about $450. I did replace the serp. belt tensioner since my mileage is 145k.
Eddie
Eddie
Taking a break at the halfway point was smart.
It's a nice feeling of accomplishment when you realize it's more time consuming than it is difficult. Patience and organization will keep you from pulling your hair out !
2KHarrier (05-15-18)
Added that special tool to my Amazon cart... will come in handy in a few years. Great post and good job!
Thanks Roman. There are other options. Starter bump method ( not a big fan) 2X4 with bolts through it, which probably would work, impact, etc.. I just like the control I had using the Schley tool.
Except with the oil changes, as the dealership does a great job in cleaning the car and checking all the fluids. For the 47.00 bucks I spend, it's well worth it for me not to deal with old oil...
Thanks John. Yeah, this is probably one of the biggest DIY jobs that can be done alone. I have other toys I'd rather spend money on than to pay some shop to do what I can do..
