slight vibration in steering wheel while idling
Old Mar 8, 2018 | 08:32 PM
Abernoots's Avatar
Abernoots
Default slight vibration in steering wheel while idling
When I'm standing at a red light I feel a small but noticeable vibration in my steering wheel. When I accelerate, the vibration seems to fo away. My car has 105k and I change the oil every 2000-3000 miles. Does anyone have any ideas as to what it might be? I know this is vague so any direction you can point me towards will help.
Old Mar 8, 2018 | 09:03 PM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
if your rpm's are normal then i would say engine mounts.Over 100k miles they seem to need replacement.
Old Mar 8, 2018 | 11:07 PM
05ls430518's Avatar
05ls430518
I have a slight vibration as well, but mine is there driving but goes away once the car is warmed up. Sometimes there is just weird gremlins that cannot be explained with cars.
Old Mar 9, 2018 | 01:03 AM
bradland's Avatar
bradland
This can usually be solved by replacing the transmission (aka "rear" engine) mount. If you have any mechanical experience at all it's slightly more difficult then an oil change. If not a trained tech with a lift can knock it out in about 15 min.
Next time you are at a red light and feel the vibration put the trans in neutral. If the vibration goes away it's probably the trans mount.
Lexus part #12371-50170
Old Mar 9, 2018 | 05:23 AM
2KHarrier's Avatar
2KHarrier
Food for thought here ^^^
Swapping my mount was very easy and it eliminated a pesky vibration I felt as well.
Old Mar 9, 2018 | 05:34 AM
Abernoots's Avatar
Abernoots
My RPM is a bit lower in drive than in neutral. Will replacing these mounts fix that as well?
Old Mar 9, 2018 | 07:23 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
when you are in drive the rpm's will be lower.No a mount will not change your rpm's
The soul purpose of a mount is to absorb vibrations .Its a piece of rubber between two pieces of metal
Old Mar 9, 2018 | 07:51 AM
Abernoots's Avatar
Abernoots
What could be the reason behind low RPM? I'm talking like 500rpm. Unless that's normal in the LS430. All my other cars were at around 800 at idle in drive
Old Mar 9, 2018 | 10:25 AM
2KHarrier's Avatar
2KHarrier
500 RPM lower, or it idles at 500 RPM when in gear?
Old Mar 9, 2018 | 10:32 AM
Abernoots's Avatar
Abernoots
it idles at around 500 rpm when in drive when I'm standing still. I looked around the forum and cleaning the throttle body and MAF sensor can possibly fix this. i just want to make sure this isn't some sort of life threatening thing to the engine
Old Mar 9, 2018 | 11:04 AM
05ls430518's Avatar
05ls430518
If it was life threatening your dash would light up like a x-mas tree so no worries.
Old Oct 26, 2021 | 08:37 AM
benhack's Avatar
benhack
Me too.😱😱😱😱
Imprezario
Oct 30, 2019 09:02 AM
cenozoite
Jan 29, 2018 01:21 PM
hms09
Jan 9, 2018 07:44 PM
james1245
May 4, 2015 07:47 AM
robobbi
26
Jan 23, 2007 12:51 PM
