HVAC blower motor inoperative!
Can you believe it? 149,488 miles and I’m sitting in a parking lot wondering why my hands are cold but my rear end is warm. It’s because the seat heater works, but not the blower for the hvac!!
Ive tried all settings (defrost, mix, face, feet) and none work. The motorized door works because I can hear it when changing modes, but the blower simply isn’t working in any of the speeds.
Grrrrreat, and we’re getting snow tonight. Glad I have my F150 for backup.
Any takers? Possibility it could simply be a blown fuse? I’ll check the cabin filter to see if there’s a tree branch blocking the motor from spinning, but doubt that’s the problem.
So pissed.
So pissed.
Good deal that it started working again. Hopefully just a hiccup.
It has been well below zero for days here. Just yesterday a fan noise started down by my glove box. If I whap on the glove box, it stops.
Is there a separate fan in the glove box area? Hopefully it will go away when the weather warms up.
It's best to totally empty out the glove box so you you don't end up cursing that there's not enough room, etc, lol. Once everything is out of the glovebox, there are 2 tabs (on the back of the glovebox) that you squeeze to undo, then take that cover piece off. That gives you access to the air filter frame that is somewhat UP in the air box. Pull the frame down a bit, then pull towards you to remove, then remove the old filter from the frame.
I would also have a vacuum cleaner on-hand. What you see when you lower & remove the filter may disgust you! I found the filter replacement difficult to do when there's low lighting, so have either a droplight, or headlight, or bright day or well lit garage, etc.
Sounds as if you have something touching the fan blades when the fan is on!
I have a thread of my first HVAC cabin and seat filter change posted here... https://www.clublexus.com/forums/ls-...lter-pics.html
Stop the whapping, and get to changing!
Let us know how you make out!!!
The fan (and the filter & filter holder/frame) for the HVAC is behind the glove box area. If you've never changed it before, do yourself a favor, and get the proper cabin filter (Purolator, Wix, Toy/Lex, whatever you choose), and change it! I personally like the Toy/Lex version, because they're impregnated with activated charcoal, which helps absorb odors better.
Hey man were did you get your seat filters from I cannot find them on Amazon or anything and I have blown them out with compressed air but I would like to put in new ones for when I drive her again in the spring.
tyncobb
Feb 12, 2019 04:37 PM
Sideshowsa
RX - 1st Gen (1999-2003)
May 21, 2014 05:00 PM
Geoff240ti
Jul 6, 2007 01:55 PM
