New pads and rotors(myself) - still squeals in reverse with pedal
OK - did pads / rotors / flushed brake fluid a few months back. Whenever I am backing up I get this loud HOWL with pressing the brake pedal. I pulled off front pads on the passenger side where I thought I heard it and nothing was out of place.
People talk about shims etc - but I just added the new pads with the rotors installed and put it back together, no other parts or 'shims'. Just what came off the car. Did I miss something or do something stupid??
Has anyone had this on their LS?
I have had same problem with centric rotors and akebono pads. I usually have just left the rotors and never an issue. I felt I had to change even though no brake pulsing, mistake if no pulsation leave rotors do not cut them also. Ya the noise will wake up the choir, worse in winter, it will get better after a year plus much better.
Akebono
Ordered on May 12, 2017 (1 item)
Bosch
So thats what I used. Its coming back to me :-) I did swap the rear pads -vendor said order and send back old as refund. So replaced rear pads and pulled front passenger pads and reinstalled.
Bosch
I've replaced front and rear pads several times, and within the last year replaced front and back rotors. I used all OEM Toyota/Lexus pads and rotors and have never had a squeak nor squeal. I did use CRC synthetic brake caliper grease on all the edges and flat surfaces of the pads that touch the calipers and piston, but more importantly, before applying the grease, I wire brushed everything then sprayed down everything liberally with CRC red brake cleaner. CRC green evaporates too quickly and doesn't clean as well.
Anyway, sometimes determining WHERE the noise is coming from is half the problem! You should try applying only the emergency brake while going in reverse and see what happens. If you don't get noise when applying parking (foot) brake to slow down, then the noise is coming from the front brakes. If you DO get the noise when applying the parking (foot) brake, then it's your rear pads/rotors producing the noise.
Something else you didn't mention is hopefully you sprayed down the rotors with A LOT of the brake clean spray, on the inside and outside brake surfaces of the rotors before installing them?! Most rotors are manufactured/packaged with a thin film of anti-rust coating so they don't rust in the package while sitting on the shelf. If you didn't liberally spray a ton of cleaner on the brand new rotors, you can still try now and see if simply cleaning the surfaces will help eliminate the squeal. Just make sure you get BOTH sides of the rotor.
I personally would try 1 solution at a time to try to determine exactly where the noise is coming from. These are both quick and easy actions that will help determine where the noise is coming from. The brake clean/spray might actually fix your issue also. I would also aim the spray tube in the 1mm space between the pad surface and rotor. This will help clean the surface of your new pads if they're contaminated with a substance.
The parking brake pads can make noise when reversing, especially on new rotors. I've experienced this myself after having the '01 parked on ramps for a couple days with the parking brake applied.
I went to back out of the driveway and heard the incessant song of the rotor... It went away after a day or so.
You may have a coating on the interior of the rear disc, where the parking brake pads ride, which could be causing the noise.
The problem here is that the parking brake shoes are, for all intents and purposes, a separate system from the back brakes even though they share the same rotor. There is a specific drum portion formed around the rotor that mates with the parking brakes shoes. So just because you don't get any noise while testing the parking brake doesn't mean that the front pads are the issue. The rear pads could be the problem also...
Wondering if OP hears the noise when applying the foot brake while going in reverse?
DroppedGS
01-15-05 12:49 AM
