MAF Sensor too good to be true...?
I don't believe these sellers even know that its a genuine part or if its a counterfeit. are you looking for a genuine part at a non genuine price?
The price is the answer. If its cheap its a non genuine part. I am going to switch my MAF back to the original part. My car has been running great with a cheap one though. They are very simply sensors not allot to worry about for substandard pieces.
The wire and resistance is the big issue and who knows if this isn't the same as a genuine part?
It just seems like you are wasting the vendors time and yours to determine what we all know as true to be true?
I am not trying to spoil your mission just to say it is probably a waste of your and their time and money.
Head to the dealer or rock auto and buy a legit part and enjoy the peace of mind knowing you are taking less of a risk in life.
If the parts they are selling work and are at a cheap price what are you trying to stop?
Just swapped the original OEM MAF back on the car. The other two are going back in my glove box.
I carry a scanner with me so my hope is I will find a Toyota driver on the side of the road and I can diagnose and install one of my extra maf's and have him on his way.
If I had a mechanic friend look in my glove box and see two extra MAFs he would figure I was pretty paranoid. A car should be able to drive a lifetime without needing to replace a MAF. I just threw away a Nissan MAF from a 1993 Quest van I had as an extra. sold the car and never needed it.
I just received a Denso MAF for my LS430 from a well known vendor on line that does quite a bit of advertising on TV etc. Clearly on the description picture it says made in Japan. When opening the package, the MAF comes in a Denso box and on the side of this box there is a label saying made in Vietnam. Back to the post office and back to the vendor. Why isn't anything represented correctly? When I purchased my front wheel bearing hub from Koyo which manufactures the hub for Lexus/Toyota it said clearly on the box, Made in Japan. Unfortunately I have to eat the shipping although I shouldn't have to because of misrepresentation. However, there is no one to speak to, so I guess I'm biting the bullet on this one. I'll keep searching.
As a side note my car throws the same 2 lean codes but only after extended periods of high speed driving. Both of my front O2 sensors are new. Do you get an occasional light engine pinging under acceleration?
I'd be willing to bet that even if you were to pony up the money for one at the Lexus dealership it would be made in Vietnam as well. This is where Denso produces them and I seriously doubt they would have two separate factories making these. These sensors with the same part number are used on almost all Toyota engines and are by no means exclusive to our cars.
I still get the lean codes on long trips. Once I clear them they are gone until my next trip. I get the light pinging which I assume is a result of a lean mixture. I also have the same issue in regards to the non-linear acceleration with dead spots. I do think that the two issues are unrelated. I still have the original MAF (I cleaned it) but everything else is newer (spark plugs, all PCV hoses, exhaust gaskets, front O2 sensors). Mine is an '01 with 134k. I have a copy of Techstream and as soon as I can get it working with my laptop I will start diagnosing everything myself.
Boca, just curious, was your Indy able to confirm that you had no exhaust leaks anywhere???
None that he could find. He also checked for vacuum leaks as a possible cause for the lean mixture on both banks being "unfiltered air". I happened to get into conversation with the main diagnostic wiz at my local Lexus dealership today who was finishing a discussion with a customer. After explaining all I've gone through with codes and my car's history, the first thing out of his mouth was the MAF. He asked.....what do you have to lose by replacing a 16 year old part that might be the cause. If not, he suggested to bring the car in while the check engine light is still on for a thorough diagnostics. Sometimes they may find it within the first hour as they have the latest diagnostic tools for our cars. Bottom line is, once Lexus finds the issue, they stand behind it regardless. I'm still hoping it's the MAF. I will report back once I do the replacement. Thanks everyone for the great advice.and feedback.
You are now going to buy one from the dealer for $130 or ? Pay $150 for diagnosis and could there be a possibility that the cheap $22 MAF might have solved the problem?
I could have sent you one of mine and had you run it for a while and then if it didn't fix it send it back. if it ran well send me $22.
If your goal is to fix the car, testing it with a cheap MAF seems like a great way to check if its a functionality problem with your old MAF?
Its one thing to check where a part is made but what seems more important is do these parts work and function like the vendors are selling them?
Bocatrip (12-09-17)
Bocatrip, did you ever try the MAFs from Vietnam?
Bocatrip,
Just a quick thought, have you checked the fuel pressure? If the pump was plugged or blocked and had low fuel pressure could that cause a lean fuel trim?
Simple test regarding fuel pressure and easy replacement of a fuel filter or pump.
http://www.import-car.com/step-step-...p-replacement/
Spark, fuel, air and compression. Fuel supply should be verified.
I don't believe these sellers even know that its a genuine part or if its a counterfeit. are you looking for a genuine part at a non genuine price? It just seems like you are wasting the vendors time and yours to determine what we all know as true to be true?
I am not trying to spoil your mission just to say it is probably a waste of your and their time and money. Head to the dealer or rock auto and buy a legit part and enjoy the peace of mind knowing you are taking less of a risk in life. If the parts they are selling work and are at a cheap price what are you trying to stop?
In progressive societies such as in the US and Canada, it isn't acceptable to conduct and condone such fraud. I don't appreciate sellers lying about their products, and neither should you. These sellers are wasting other people's time and money with false advertising, and in turn, I'm wasting their time and money by calling them out on it.
If these sellers don't know that something is truly Genuine OEM Denso Toyota, then they shouldn't list it as such. If they don't know what the meaning of "genuine" means, then they shouldn't be using the word. If they don't know that the part is manufactured by Denso or Toyota, then they shouldn't select Denso or Toyota as the manufacturer of the item. There are many other manufacturers to select from, including "unspecified". They could easily list their products accurately, but they choose not to do so.
I have no problem with sellers listing non-OEM MAF sensors without lying about the details. I am sure these non-OEM MAF sensors would work just fine, but maybe won't last as long as OEM. If people want to knowingly buy a non-OEM sensor, go right ahead. I just have an issue with the false and fraudulent product advertising.
These sellers are trying to scam buyers all over the world. It only takes me a few seconds to browse the listing, confirm it says "brand new unopened genuine Denso Toyota" in the official description fields, save a screenshot of it, click Buy Now, and then upon receiving an item not as described, click the Request Refund button and all of my money is back in my account within 48 hours.
If anyone wants to buy used OEM or unused non-OEM MAF sensors, I have a few available
If anyone manages to obtain a new OEM sensor at a good price, this would be the thread to tell us where you got it from. Easiest way to tell if it is OEM is if you know for sure your existing MAF is OEM (either installed from factory or you have a new one directly from a Toyota/Lexus dealership to look at), then compare the markings on the top - they should be identical in every way. Genuine OEM has 5 rows of raised text just like the middle MAF in coug66's picture above, and I can confirm the MAF installed at the factory in my 2002 LS430 looks like that.
Actually Stan Van Dam......I've contacted and asked vendors with all the original 5 rows of raised text on their $20+ MAFs listed on ebay only to find out these items were made in China! Once again counterfeiting is alive and well on ebay. Another secure method on getting the right product is to buy from a Toyota/Lexus dealer on ebay or Amazon and/or not buy from a 3rd party vendor. Either buy directly from Amazon (not a 3rd party vendor listed with amazon) or a reputable business like RockAuto etc.
