wind noise solution
Old Sep 2, 2017 | 04:16 PM
Stu's Avatar
Stu
Default wind noise solution
I've had wind noise coming from the driver side area for the past 5 years. I tried shin-etsu Grease but it didn't work. I've learned to live with it.
Today I used Gorilla Tape to reinforce some of the moldings and contact points where the door closes. It worked like a charm because the tape is strong and thick enough that it fills gaps nicely without interfering with the door closing. My cabin is dead silent now and no rubbing/creaking noises of any kind. If your cabin has wind noise, try it, it really works
Old Sep 2, 2017 | 06:53 PM
lsdude's Avatar
lsdude
Hi Stu. Can you post pics of your solution?
Old Sep 3, 2017 | 03:23 PM
Stu's Avatar
Stu
Its made a huge difference. I used to think the window was loose for the longest time .... and I was wrong.
I can show you what I did but it probably wont help you much, unless your car is leaking from the same locations ..... give me a few days and I will put them up.
Old Sep 5, 2017 | 02:49 PM
Stu's Avatar
Stu
here are the pictures of where I put the Gorilla tape. It's on the inside of the doors and gives extra strength to the thin plastic strips that are visible from the outside of the car. The tape is only visible when the door is open and since its black its quite hidden. the other place I used it is in the areas where the rubber moldings seal against the cars frame. This is where my air leak was coming from and my car is dead silent from the wind noise. There was an odd squeak when driving on bumpy roads.and.its gone too. Huge improvement because the car is noise free !
Old Sep 5, 2017 | 02:55 PM
bloomwcjkl's Avatar
bloomwcjkl
I am going to try this on my 01 LS 430. I have a wind noise that sounds similar to yours. Thanks for the photos.
Old Sep 5, 2017 | 08:16 PM
lsdude's Avatar
lsdude
Thanks Stu! I'll give this a whirl too.
Old Sep 5, 2017 | 11:35 PM
ALISC400's Avatar
ALISC400
Thanks Stu,
I've done something similar on my ES and have had a friend who's suffering from the same problem - hope this fixes it
Old Sep 26, 2017 | 10:06 PM
RRocket's Avatar
RRocket
The only time I get wind noise, is when I lower my window...then back up: noise.
Then if I lower window a smidge, noise gone. Then after a minute or two I can put the window back up and noise gone.
It's very odd.
Old Sep 27, 2017 | 12:34 PM
bloomwcjkl's Avatar
bloomwcjkl
It's very odd.
I have had vehicles like this. The window goes up too far and it pulls/separates the rubber gasket on either side of the window and causes the air noise.
We had a new 1998 GMC Jimmy that did this. The first week we owned it, I had to roll the window up and then move it down just a bit. If I went to far I had to repeat. I had it in 4-5 times. They could not fix it. We got completely rolled on that vehicle. Sold it about 1 year after buying it.
Salil022
GS F (2016-present)
32
Nov 10, 2018 03:05 PM
lexflyer
Nov 18, 2015 12:43 PM
danny404
NX - 1st Gen (2015-2021)
Mar 11, 2015 06:30 AM
e-Mel
Sep 30, 2006 05:21 PM
