How to free Sticky Switches
Old May 27, 2017 | 10:56 AM
ahde's Avatar
ahde
Default How to free Sticky Switches
I have hung a bottle of liquid air fresher at the centre vents right above the front, rear window defogger and air-conditioning auto switches. Unfortunately, the bottle leaked and the fluid was erosive and melted the plastic skin on both the front and back of these switches making all three switches sticky and can not function. I have tried to free them with all sorts of solvents but it only got worse and the plastic skin melted even more. I have visited a few car detailing companies but they can do nothing but recommend to replace the entire panel. I just wonder if any expert here have the same experience and can offer a better solution. Thanks.
Old May 27, 2017 | 11:26 AM
LS430Lexus's Avatar
LS430Lexus
Find one on ebay and replace the panel.
Old May 28, 2017 | 01:28 AM
ahde's Avatar
ahde
Tried but no luck. Anywhere else pl.?
Old May 28, 2017 | 04:42 AM
lextout's Avatar
lextout
u may be sol
Old May 28, 2017 | 07:21 AM
LS430Lexus's Avatar
LS430Lexus
Just noticed you were in Hong Kong. You may have a different version. In addition, it appears you have Mark Levinson with no Nav. I am not sure if that makes a difference. I might try to buy the US version of the climate control unit from ebay and try to make it work. You may also be able to take it apart using the new "used" parts to repair your original unit. In addition, you might want to check the cost of a new part at the dealer.
Old May 29, 2017 | 10:46 AM
ruleman's Avatar
ruleman
I had a similar situation with a Lexus GX that I purchased, where someone had spilled a coffee on top of the dash buttons and let it sit un the sun and dry... #$!#%$!%^$%!!!!! (and to think they let these people vote!)
But I digress. In my case, I took the panel out and carefully disassembled each button to clean them up one by one with nothing more than a mix of water and isopropyl alcohol (rubbing alcohol). This took all the grease away and let the buttons work freely again. I suggest you try it if you are good at DIY work.
Luffy808
Hawaii and Guam
May 3, 2017 01:47 AM
XeroK00L
Great Deals
Feb 13, 2006 03:54 PM
XeroK00L
Great Deals
20
Jan 19, 2006 08:25 AM
