CD Stuck Between Discs? "CD Error" Help!
Old Jul 5, 2020 | 07:24 PM
mcgrath64's Avatar
mcgrath64
Default CD Error Fix - Which worked for me
Hope this works for you.
  • Check to see if there is a CD stuck in the "load slot".
  • If so, using a tweezer pull the CD out.
  • Then, eject all remaining CDs in deck.
  • Turn off power to CD player
  • Turn on and retry - Fixed for me.
Old Jul 6, 2020 | 09:30 AM
Trilkb's Avatar
Trilkb
Think this happened to me once, Cd was changing and hit a large bump. My solution was to hit the side of the center console hard as **** and bingo, it worked again. Got my discs out and only run one at a time now.
Old Jul 7, 2020 | 08:00 AM
infojunky's Avatar
infojunky
I used the piece of tape backwards on credit card to fish out disc.
Old Mar 13, 2021 | 12:54 PM
victorjohn's Avatar
victorjohn
Thumbs up CD Player Reset - Battery Disconnect
You guys rock! The CD player in my 2006 LS430 was stuck. Each time I turned my car on or tried to switch to the CD player I would hear a buzzing noise for about 5 seconds or so and the words CD Error would come up on the screen. I was preparing myself to spend hundreds of dollars to get it repaired when I saw this post. I disconnected the negative battery terminal for 10 minutes and then reconnected the cable and sure enough the CD player worked again. I didn’t even lose any of my preset radio stations or other settings. Love that! Two things I love the most is fixing stuff myself and saving money! Thanks guys!
Old Apr 5, 2023 | 05:22 AM
drbdjones's Avatar
drbdjones
Yes, you guys do rock. I had a feeling that a battery disconnect might work but after reading this post I decided to give it a try. Low and behold my CD player is working again. Now my wife and I can travel in luxury and listen to Books on CD. Thanks Club Lexus.
i3leusky
Apr 6, 2015 02:09 PM
Bucketlist
Jan 24, 2015 01:27 PM
Taka
24
Nov 7, 2003 02:09 AM
Philly#1 Lex
Feb 16, 2003 07:58 AM
tacshose
Nov 15, 2001 11:37 AM
