Drivers side mirror
Old Dec 20, 2015 | 09:14 AM
moodyblues's Avatar
moodyblues
9th Gear
Default Drivers side mirror
I accidently puts this is the IS forum.
2004 LS430 and I have have read the other threads concerning the mirror.
Mine will move up, down, to the left. It will not move towards the car to use for driving.
Old Dec 20, 2015 | 11:09 AM
2KHarrier's Avatar
2KHarrier
Can you move it manually? By hand?
Old Dec 20, 2015 | 08:32 PM
bmore430's Avatar
bmore430
You can try cleaning the switch contacts first to see if that is the issue. If you clean the switch and the symptoms remain you may need to rebuild or replace the mirror assembly because the motors inside are failing.
I just went through this on my 2005. My driver mirror would function perfectly except for the up and down. I cleaned the switch and nothing changed. I then ordered a new mirror and once it was installed everything worked perfectly again.
Old Dec 21, 2015 | 01:19 PM
lev00221's Avatar
lev00221
Yes, order the new mirror. Installation is extremely easy.
Old Dec 21, 2015 | 03:40 PM
moodyblues's Avatar
moodyblues
9th Gear
I can move manually but when I try to move to the right it starts bumping.
nolen01
Feb 19, 2016 08:02 AM
mar1
Oct 16, 2014 10:38 AM
MellonC00
RX - 1st Gen (1999-2003)
Dec 26, 2013 07:26 AM
IsFast3r
IS F (2008-2014)
Dec 7, 2012 08:40 PM
